Post 306194 by Happygilmore78 on 2010-05-04 15:18:53
My power steering resevoir is leaking from the top through cap and bottom, so have ordered a new one to replace it this week.
Am i right in thinking, just empty out resevoir using whatever method i can, clamp two pipes, undo 2 pipes (which i just know isnt going to be that easy, i remember my fuel filter) and voila, bung in new one, attach pipe, unclamp and fill resevoir with fluid....
...or is there some kind of certain satanic ritual i must adhere to regarding bleeding etc.......please say no...... :cry:
Cheer guys
Post 306199 by Wobbly Dave on 2010-05-04 15:31:07
It's easy - once you have removed the old one and clamped the new reservoir in place - fill to the line on the dipstick & then use the steering wheel to rotate lock to lock 2 or 3 times.
Check level.
Repeat until level is stable (perhaps twice)
Any bubbles in the hydraulics should pops to the top.
Post 306309 by Wobbly Dave on 2010-05-05 01:35:35
Forgot to say - when you turn the steering wheel - obviously the engine will be running (& subsequently the PS pump)
Post 308514 by lordvague on 2010-05-13 19:00:08
wait for end of the year when the new gpus come out, you have enough power to last and it will be the EPIC DX11
