19" wheels but what tyre-size?
Post 310315 by chrjen on 2010-05-21 20:03:09
Just bought me some 8x19" ET38 OZ Palladio for my 1997 V70, but which tyres will fit without rubbing. The car is lowered app. 40mm - I think it is a H&R or Eibach kit. Im thinking 215/-19 or 225/35-19...
Post 310359 by Wobbly Dave on 2010-05-21 21:17:18
I have 225/35/19s on the front - small rub on full lock, depending on tyre - the bridgestones don't hardly rub at all.
Post 310372 by volvokid on 2010-05-21 21:27:13
My V70 has standard suspension and with the 19" wheels I can barely get my fingers between the arch and the tyre. Good luck with your set up.
Post 310513 by Happygilmore78 on 2010-05-22 22:50:03
I have 225/35/19 on a car lowered 35mm - no rubbin whatsoever, even with 4 people in. Also no rubbing anymore on lock since installing the lock stops i got off Simon that were missing of mine originally.
Post 310514 by Wobbly Dave on 2010-05-22 22:52:59
I have 265 (so ner!! :P ) on the back which are PHAT - as such I had to have the arches rolled.
Post 310528 by t5_monkey on 2010-05-22 23:47:34
Won't it ride in a manner that would make Max Mosely plead for mercy with 19" inchers on ??
Post 310530 by Wobbly Dave on 2010-05-23 00:04:13
Actually the ride is not as bad as you might imagine. I have quite firm shocks on bilstein B3 - and it is quite pleasant as long as the roads are not too nasty.
Post 310543 by t5_monkey on 2010-05-23 08:49:53
[quote=Wobbly Dave;310530]Actually the ride is not as bad as you might imagine. I have quite firm shocks on bilstein B3 - and it is quite pleasant as long as the roads are not too nasty.[/quote] That's good - the potholes and knackered scottish country roads are something else up here, mine was horrible with the 18 inchers on and standard shocks. How much firmer are the bisteins than stock? a damper upgrade is on my agenda at some point...
Post 310554 by Wobbly Dave on 2010-05-23 10:40:19
They are an excellent shock not at all crashy. I've previously had KONI FSD - which were less expensive and nearly as good. Really depends what kind of ride you are after.
Post 310581 by t5_monkey on 2010-05-23 13:12:59
[quote=Wobbly Dave;310554]They are an excellent shock not at all crashy. I've previously had KONI FSD - which were less expensive and nearly as good. Really depends what kind of ride you are after.[/quote] Mines quite firm and handles well but can feel a bit unsettled on rougher roads, a smidgen underdamped basically - which is logical considering its on stock dampers and has done 47,000 miles (a fair few of them on Scottish backroads) and harder eibach sports springs. I like the firm tied to the road feel - esp on turn in and the longer sweeping fast corners. Have you ever had coilovers? I'm wondering if they're much better than upgraded shocks and springs
Post 310695 by Wobbly Dave on 2010-05-23 22:44:59
Never had coilovers - don't want them either - horrible feel.
Post 310738 by Happygilmore78 on 2010-05-24 12:33:22
I was going to get coilovers, but after some advice (Wobbly) am going for Koni FSD. I think the ride on 19's is ok actually, you obviously feel more of the road as our tyres look like a stick of liquorice rapped around the rim, but all in all not bad at all. My mother has severe back problems, her spine is crushed so basically any jolt and its noticed and she loves riding in the car, says its one of the most comfortable cars she has ever been in - and she rode in it before the 19's and lowering - so thats saying something.
Post 310740 by t5_monkey on 2010-05-24 12:48:54
[quote=Wobbly Dave;310695]Never had coilovers - don't want them either - horrible feel.[/quote] What do coilovers feel like...?
Post 310743 by Wobbly Dave on 2010-05-24 13:56:40
they make the car wobble from side to side - made me sea sick.
Post 310745 by Al115 on 2010-05-24 14:05:30
Whereas my coilovers didn't wobble at all, but were definitely more suited to (let's say) "good roads" (and we don't have many of those in Herts) :D I was happy to spend my life avoiding potholes in return for the better cornering, but many people aren't!
