Post 312880 by mightywolf on 2010-06-03 21:50:59
Gonna service my S70R at the weekend. Whats the best engine oil to use? Its a '98 automatic and done 160'000. I'm gonna give it an engine flush aswell, but want some good oil in it. Suggestions?
I'm gonna change the gearbox fluid aswell I think and have I got to get the volvo stuff from the dealers? Have I heard right that if you use aftermarket gearbox fluid it could knacker the gearbox?
Post 312924 by Porcine_Aviator on 2010-06-03 23:45:11
I use Castrol Magnatec and it works well in both of our T5s, we change the oil every 6000m or 6 months.
As for the gearbox Volvo Auto fluid if you want to go for the recommended, but the are other oils.
Have a look on here http://www.revolutionoil.co.uk/lubricants/transmission.php. They have some info in Dexron III
Volvo's recommended Autobox fluid was Dexron IIE (or Ford Mercon) when your car rolled off the line. This was upgraded to Dexron III which is backwards compatible with Dexron IIE
So if you look around for a good quality Dexron III you should be OK. You might like to ask RUFE for some advice if you want more info.
Post 313490 by SAMXPJ on 2010-06-06 22:03:06
At that milage I would not flush the engine, the carbon/metal deposits that have built up it otherwise unaccessable places will be removed by the flushing detergents and in particular the crank shaft float. I would just refill with Castrol Magnatec - T5s love it!
Post 313498 by The Flying Moose on 2010-06-06 22:23:02
I always use Mobil Super S its about £30 a bottle and the car purrs when she is filled up with it. Upon failing that castrol magnatec anyday.
I always find http://www.opieoils.co.uk/ quite competitive if you need a supplier.
Post 313499 by WOODY T5 on 2010-06-06 22:24:55
i use millers oil runs sweet on that
Post 313787 by mightywolf on 2010-06-07 21:14:27
went for mobil super s. Sounds really quiet and purrs now :)
Post 313791 by The Flying Moose on 2010-06-07 21:20:29
[quote=mightywolf;313787]went for mobil super s. Sounds really quiet and purrs now :)[/quote]
Good choice if I dont say so myself. Never let me down the old Mobil oils.
Post 313792 by mightywolf on 2010-06-07 21:24:42
well i thought I'd go for something I'd never tried before. And like I said it seems to be sweet!
Post 313804 by SKIDMARKS on 2010-06-07 21:58:59
[quote=SAMXPJ;313490]At that milage I would not flush the engine, the carbon/metal deposits that have built up it otherwise unaccessable places will be removed by the flushing detergents and in particular the crank shaft float. I would just refill with Castrol Magnatec - T5s love it![/quote]
Agree with this 100%. You could even block an oil return from the head and kill a good engine.
Post 313806 by SKIDMARKS on 2010-06-07 22:04:03
[quote=smithness;313499]i use millers oil runs sweet on that[/quote]
Use this in the kit as it is extremely good with high oil temps but would only use a standard oil like Magnatec in in the tintop
Post 313831 by SAMXPJ on 2010-06-07 23:26:50
Mobil 1 or equiv is great for a new or nearly new engine - used it in my cosworth from new and carried on using when modified up to 375bhp with no problem but to put it in an engine that has done 160k that also has had a higher sae oil in before is sure going to rattle. If the engine had always been run on a fully synthetic oil of around 5sae then great but this engine as I understand it has not!
Post 313837 by mightywolf on 2010-06-07 23:52:45
mobil super s is semi syth. 10-40w. It doesn't sound noisy, it sounds much quieter than before?! How would flushing the engine block an oil return or cause damage? I've never heard that before?
Post 313875 by SAMXPJ on 2010-06-08 11:04:17
I'm talking about the fully synthitic Mobil 1 or equiv that is 5 sae. If an engine has been run for say 100k on a none synthetic oil and one that does not have a high detergent present then over time carbon and other deposits build up at the main bearings of the crank shaft [the design of the crank requiring a small amount of end float] If after 100k those deposits are removed then the crank will now have more lateral movement, we are only looking at maybe a thou or two but this now means that the big end bearings that have formed their niche over time will now have more lateral movement to the con rods then to the small ends etc etc. This whole process having a loosening effect. I have seen it, measured it and listened to it on a lot of engines. I am not saying that this relates to this particular engine or not because the history is not known but just in case I would not use a fully synthetic oil on a 160k engine of unknown origin.
Post 313920 by mightywolf on 2010-06-08 16:28:17
cheers, yeah I wouldn't use a semi synth oil on an older engine. Good bit of info that and something to take into account :)
Post 313925 by Filterlab on 2010-06-08 16:46:26
Anything well regarded and 10w40 semi. My mechanic always recommended semi over fully-synth for the T5s, not sure why though. Anyway, he always used 10w40 semi and I never had a problem at all, the engine had just under 180k when I sold the car and it was running perfectly.
