850 oil leak
Post 312960 by Mongo on 2010-06-04 10:47:20
Hello everyone I have a volvo 850 t5 it had an oil change and shell mineral oil was used (not good) after a few weeks i was doin around 90 mph and a tapping started im guessing lifters? I removed the rockerbox to check for damage all was ok. I replaced the cam seals and cambelt Filled her up with 10 30 fully sinthetic oil and bolted it all back together. I noticed oil leaking from a small hole on the rocker which i belive is a redundent oil return to the turbo, it is located between spark plug3 and4 thrre was nothing stopping the oil cumming out and never realy noticed but now it is and i cnt stop it. Ive replace the oil filler cap rubber because that was leakin. Any thoughts on the redundent hole? Many thanks joe
Post 312962 by Rnash2002 on 2010-06-04 10:57:08
hi mate you mean the breather for the pcv system,there should be a rubber hose running from the hole down the front of the engine to the pcv container. I take you have no rubber pipe coming from the top of the bloke?
Post 312963 by Rnash2002 on 2010-06-04 10:59:54
Image Yours should look like that.
Post 312964 by Porcine_Aviator on 2010-06-04 11:02:24
[quote=Rnash2002;312963]Image Yours should look like that.[/quote] Big image no linky :)
Post 312965 by Mongo on 2010-06-04 11:12:03
Yea i cant see the pic should this hole be blanked off?
Post 312966 by Mongo on 2010-06-04 11:48:01
Im just stuck on this hole ive but it in a garage and they dont no what to about the leak either you people on here are my last resort. Mant thanks
Post 312986 by Rnash2002 on 2010-06-04 14:01:35
strange how you cant see that. Ok try this. Image
Post 312990 by Mongo on 2010-06-04 14:12:15
Thats better. Well to the right of where the number 3 ht lead is pulled out theres a hole about the size of a penny with two offset bolt holes you can jus see it in the pic. Thats where oils leaking. Thanks mate
