Air con regas valve 850 T5
Post 313347 by davie b on 2010-06-06 14:01:13
Anyone got any ideas where the A/C regas valve is for an 850 T5 ? Cheers Dave
Post 313367 by Alan M on 2010-06-06 15:59:31
Behind the drivers side headlight on RHD cars. They do tend to stick though when you apply a vacuum to the system before a recharge so just be careful as they can cause moisture and air to be taken into the system if you break the joint for recharging the system.
Post 313370 by davie b on 2010-06-06 16:14:46
Thought that was it , thanks . I've just put some gas in but the pressure is up and down like a yoyo with the clutch engaging/clicking in and out every couple of seconds , i'm wondering if the problems a bit more than just a re-gas Anyone any ideas ?????
Post 313378 by Alan M on 2010-06-06 16:48:13
Best to take it to an engineer capable of diagnosing any faults. It does sound like the gas is still in need of topping up.
