hu 803 & ipod
Post 316195 by ngt68 on 2010-06-20 22:14:25
hi guys, my problem is, i have a stuck CD in the unit, and it gives the usual 'error' message, i've tried everything to get it out, but failed! what i'm wondering is, if i fitted a 'hard wired' ipod kit, would it work with there being the stuck disc, and 'error? hopefully somebody knows! cheers, neil.
Post 316210 by Wobbly Dave on 2010-06-20 23:09:29
I am pretty good at getting cd's out of those things. If you send it to me I will get it out and send it back?
Post 316219 by Storm-Troll on 2010-06-21 00:16:37
[quote=Wobbly Dave;316210]I am pretty good at getting cd's out of those things. If you send it to me I will get it out and send it back?[/quote] you gonna use that heavy mallett again?... problem solved lol.
Post 316258 by Libra on 2010-06-21 12:26:54
Don't you have to get the HU re-programmed at the dealers if you disconnect it from the cars wiring?
Post 316286 by dobbin on 2010-06-21 14:33:52
if its the original unit you should get away with it as its already matched up to the car and i think the 801/3 units dont need a code either? hope fully you should be able to plug it back in and have no probs, there are a few tips if you search for getting stuck cd's out of the units, have a search in here
Post 316324 by Wobbly Dave on 2010-06-21 16:43:34
[quote=Libra;316258]Don't you have to get the HU re-programmed at the dealers if you disconnect it from the cars wiring?[/quote] Yes - you have to have the code. If you don't have it you can get it from Volvo
