Where is the space to get through to the engine bay?
Post 316832 by RICA340 on 2010-06-24 09:55:21
Hiya Im wiring my sub/amp in today, however I cant seem to find a gap/hole through into the engine bay so I can get the wire to the battery.. Any ideas? Its an 850 T5 Thanks
Post 316842 by orse on 2010-06-24 11:38:59
I believe there is a rubber grommet on the passenger side in the bulkhead.Make a nice tight fitting hole and feed the wire through there.hope this helps
Post 316849 by RICA340 on 2010-06-24 12:08:07
great il go and have a look now. Thank you
Post 316881 by mds on 2010-06-24 14:34:50
There is a permanent live feed and an ignition control at the radio. Why not tap into these then your Amp will turn on and off with the radio. Unless of course its a mental amp (to loud for us old folks) that needs a 30amp clean feed?
Post 316883 by p fandango on 2010-06-24 14:51:51
& also depending on the gauge wire there are a few spare grommets by the throttle cable
Post 317129 by RICA340 on 2010-06-25 11:27:11
all sorted now thanks :D
