Post 322745 by well-dweller on 2010-07-24 13:11:07
Hi. My metal rear coolant pipe needs replacing. Looks like a previous owner had a hole, so cut the pipe where the hole is and joined the two ends with a bit of rubber hose. Badly. This metal pipe runs at the back of the engine and connects, at the gearbox end of the engine, to the bottom radiator hose. Can anyone provide me with some pics of the coolant pipe installation (can't see much from above), and advice on how to replace it? Is it a pig of a job to do? Where will I get one from? Thanks
