V70 Random Alarm Going Off
Post 323140 by drax on 2010-07-27 14:07:11
All, I'm hoping that I can get this issue sorted out once and for all. My Phase 2 Alarm keeps going off. I found that the company that fixed my roof hadn't put the Mass Movement Sensor back into the plastic holder mid roof on the car, however it is still going off, be it not as much. (Before the work I've had no problems.) They did remove the roof lining to get to the roof, could they have missed putting some poppers or holders back in that held the lining in correctly. Also the plastic holder seems loose? Any help would great.
Post 323171 by t5 stealth on 2010-07-27 18:44:03
maybe get it plugged in to a diagnostics might tell you more, the v70 p2 do have issues with alarms,usualy its silent,not going off,so it maybe a sensor at fault,but its guess work until you plug it in...sorry
Post 323183 by cookie on 2010-07-27 19:16:04
loose coins or metal in cabin, bonnet catches............... you really need to get car read on BSR/VCT/Auto Diagnosis to see whats logged Seeing as you are in Bristol, it may well be worth contacting MRG
Post 323184 by Vikingxl on 2010-07-27 19:19:12
try leaving the sensor from the roof unplugged and see it that solves it
