Post 323832 by MrMark on 2010-08-01 20:07:02
I am in the midst of removing an engine from a V70. I've removed them before but only when breaking, this one is being removed to be repaired. Can anyone tell me does the loom unplug anywhere or does each and every connector have to be disconnected from the engine? Whilst the engine is out it is having a new gearbox, PCV system, stage 0 service, timing belt, water pump and rear main oil seal. Is there anything else I should consider doing whilst the engine is out?
