Post 328421 by Wheelspinwardrobe on 2010-08-29 12:43:46
Is there a bung that a wire can go through 850 bulkhead? any help appreciated, battery side if possible!!! If so any ideas where? Thanks Phill
there is one on the battery side, hidden right behind the ABS unit, quite a big grommet. You'll need to take out the glovebox lining to get to it from the inside & its still hidden behing the heater motor the easiest one is on the drivers side, its the same grommet the throttle cable (just follow it to the bulkhead) uses & has 2 or 3 nozzles sticking out the grommet spare, you simply cut the end of the nozzle off & feed the wire thru
All sorted many thanks!!!! all is working now with memory!!!!
