limited to 140mph
Post 331283 by Harverd-T5 on 2010-09-13 19:22:58
A V70-T5 limited to 140mph? Surely not!? When mine hits the 140 mark it feels like its hit the rev limiter? I actually looked down to see if i was in fourth!
I have only taken the car to this speed twice, first time it hit 140 and went into limp mode and i slowly coasted back to a standstill, but i assumed this was because i was low on fuel. after turning off the engine and restarting i was off again. This time tho i had more fuel, but car did not go in to limp mode. Just felt like i was hitting the rev limiter?
Am i just unlucky enough to have a limited car(seems strange being its ex police and to 140mph) Or could there be a fault somewhere?
Any ideas?
Harvey.
Post 331284 by p fandango on 2010-09-13 19:26:08
even 850's are factory limted (can't remember if its 150-155mph), with the speedo inaccuracy you could be hitting that
Post 331286 by Harverd-T5 on 2010-09-13 19:31:03
I guess it could just be that. In the history for the car, it has a print out for the speedo calibration and say its accurate to within 0.5 of a mile an hour. Running with a sat nav read out, that and the speedo match exactly....?
Harvey
Post 331289 by siamblue on 2010-09-13 19:34:06
The American ones were limited to 140mph,
Post 331290 by Harverd-T5 on 2010-09-13 19:37:08
Ok, is there a way to tell if its an american model?! Its obv not left hand drive!
Post 331293 by siamblue on 2010-09-13 19:42:13
Yours won't be American, the ones in the States had the speedo read upto 140mph.
Post 331297 by Harverd-T5 on 2010-09-13 19:45:17
Ah, thanks.
Post 331399 by Unknown on 2010-09-14 09:30:42
My 2001 S60 T5 showed my needle flickering around 160 mph. Im guessing this was actually a bit slower in reality. It was hard to tell if it hit a limiter or just reached its maximum. Didnt dare keep at that speed for too long to see if it would edge any higher. Anyone know if that is artificially limited or just what they can do? Achieved impressive 8 mpg at that speed.
Post 331404 by wegal on 2010-09-14 09:47:11
The Phase2's are limited to 155mph according to the volvo literature. There is no reason for the car to hit limp mode just cos you hit the speed limiter ( which i doubt you did with a 140mph reading) volvo speedo's are pretty accurate, so your recorded 140mph was probably not that far off.
Sorry but I think you have a different problem, if the car runs fine normally then Im gonna guess you have a fuel or boost issue and the ecu is tripping limp mode to protect the engine. Maybe running too lean and the exhaust gas temp getting to high, only way your probably gonna find the answer is on a rolling road, its kinda hard to do tests at 140mph. At least on a R/R you can get your afr's and tons of other data recorded to see what is happening.
Post 331406 by t5_monkey on 2010-09-14 09:53:20
[quote=wegal;331404]The Phase2's are limited to 155mph according to the volvo literature. There is no reason for the car to hit limp mode just cos you hit the speed limiter ( which i doubt you did with a 140mph reading) volvo speedo's are pretty accurate, so your recorded 140mph was probably not that far off.
Sorry but I think you have a different problem, if the car runs fine normally then Im gonna guess you have a fuel or boost issue and the ecu is tripping limp mode to protect the engine. Maybe running too lean and the exhaust gas temp getting to high, only way your probably gonna find the answer is on a rolling road, its kinda hard to do tests at 140mph. At least on a R/R you can get your afr's and tons of other data recorded to see what is happening.[/quote]
I second that - sounds like a mechanical issue with the car.
Post 331409 by Storm-Troll on 2010-09-14 10:01:05
[quote=t5_monkey;331406]I second that - sounds like a mechanical issue with the car.[/quote]
I third that..... deffo a problem somewhere.. My S60 T5 will go well past the 160 on the clock and my Gps Speedo Clocks it at 164 before I run out steam
Post 331411 by p fandango on 2010-09-14 10:09:36
[quote=wegal;331404]volvo speedo's are pretty accurate, so your recorded 140mph was probably not that far off.[/quote]
Bonny's speedo is 8mph out even at only 70mph
even tho limp home mode has cleared the fault code might still be logged on the ECU so may not need to re-enact the problem
Post 331420 by wegal on 2010-09-14 11:29:29
[quote=p fandango;331411]Bonny's speedo is 8mph out even at only 70mph
[/quote]
Has Bonny had different size wheels or something cos that error is huge. My speedo on my S60 T5 phase 2 reads exactly what the gps reads. Most volvo's ive been in have all read within 1 or 2 mph of the gps.
Excellent idea on getting the codes read... I never thought of doing it the easy way ! That said if the codes havent been cleared for a while, it maybe difficult to work out which one caused it, so probably need them cleared then re-enact the problem. I know on mine that after 6months the fault log is as long as my arm, but there is nowt wrong with the car, it just records everything, even if it was a blip.... hell mine even records a fault code if i leave the front fogs on too long !!!
Post 331423 by streaky744 on 2010-09-14 11:35:27
so what private roads are people using to do these speeds?
thought the gearing on most cars mean't they ran out of go at a true 161mph.
my old v70 with calibrated speedo would not do more than 159mph on a 4 mile run of private road as hit rev limiter.
and also found out that when flat out, full tank of fuel to empty is 12 minutes.
Post 331426 by Flatout Phil on 2010-09-14 12:01:06
[quote=streaky744;331423]also found out that when flat out, full tank of fuel to empty is 12 minutes.[/quote]
That long huh? :)
Post 331433 by wegal on 2010-09-14 12:38:37
wow your fuel economy must be bad, at 140 mph mine is doing about 4 mpg, 75 litre tank approx 15 gallons so i get 60 miles travelled at 140 mph I think thats 22.5 mins.
even so its not very long or very far and best part of £100 worth of fuel !
Post 331441 by lance on 2010-09-14 13:53:02
My phase 2 would T5 would hit 160 on the speedo no problem, you need to get it looked at!
Post 331443 by v70torslanda on 2010-09-14 14:03:39
Wot 'e sed!
Post 331453 by Flatout Phil on 2010-09-14 14:57:24
Wish I could find some private roads that were four miles long...
...but I fear I may find myself less Flatout than once I was. :(
Post 331456 by v70torslanda on 2010-09-14 15:08:24
[quote=Flatout Phil;331453]Wish I could find some private roads that were four miles long...
...but I fear I may find myself less Flatout than once I was. :( [/quote]
Try doing Paris to Calais up the A16. Midnight on a Saturday night. It's deserted.
Post 331476 by Harverd-T5 on 2010-09-14 16:03:01
Thanks for all the input people...looks like il be getting it hooked up and fault codes read then!
Anyone know of a good place in cambridgeshire or suffolk that would do such a thing?
Cheers
Harvey
Post 331486 by p fandango on 2010-09-14 16:47:28
[quote=wegal;331420]Has Bonny had different size wheels or something cos that error is huge. My speedo on my S60 T5 phase 2 reads exactly what the gps reads. Most volvo's ive been in have all read within 1 or 2 mph of the gps. [/quote]
no that's ok the standard tyre size, i'm going upto the same size as the S60R because she's having BT's 18's but not looked how that will affect the speedo yet
Post 331488 by p fandango on 2010-09-14 16:53:03
[quote=wegal;331420]hell mine even records a fault code if i leave the front fogs on too long !!![/quote]
what you doing with the front fogs on anyway, can't remember the last time i needed them. You've not upgraded from a Saxo have you? :shifty: lol
Post 331566 by wegal on 2010-09-14 22:45:24
lol.... went over shap last weekend couldnt see 10 feet in front of my face... G/F lives in cumbria and I live in manchester, can get a wee bit misty through the lakes.
Sadly i never owned a saxo Im kinda to old, but I did have a Vauxhall Nova 1.3SR which i guess was the paxo of its day :-)
Post 332211 by s60tdale on 2010-09-19 15:02:27
[quote=Flatout Phil;331426]That long huh? :)[/quote]
you must drive like a girl lol 12 mins like driving miss daisy
Post 332442 by Unknown on 2010-09-20 13:26:57
or A1M at midnight sh**ing yourself because there are Police around there all the time. Not me obviously.
Post 332443 by Unknown on 2010-09-20 13:32:31
[quote=v70torslanda;331456]Try doing Paris to Calais up the A16. Midnight on a Saturday night. It's deserted.[/quote]
or A1M East of Leeds at midnight sh**ing yourself because the Police are everywhere around there all the time. Not me obviously.
Post 332839 by Barnsley-Bill on 2010-09-22 11:15:35
Try a wallbro fuel pump then book Bruntingthorpe proving ground' a few of us went there for loging our cars a few months back' the best 60 qiud i've spent :).
160 mph + on the gps ;)
