Post 337252 by T5frankie on 2010-10-09 12:21:56
i've found a set of blue injectors, i asked the bloke what car they are out of and he said a 1998 c70 t5 so either they are not what he is saying they are or someone has upgraded this car in the past, these are not standard fitment to this car is this correct
Post 337432 by smithy on 2010-10-10 08:39:25
check the part numbers mate before fittment
Post 337446 by T5frankie on 2010-10-10 11:06:16
[quote=smithy;337432]check the part numbers mate before fittment[/quote]
ok are they written on them?
Post 337514 by T5frankie on 2010-10-10 17:54:46
can i fit greens on my car and they would fuel it no problem without extra work?
Post 337524 by p fandango on 2010-10-10 18:31:26
you might get away with upping to blues without a remap, but greens i think is pushing it too far
Post 337525 by T5frankie on 2010-10-10 18:39:38
[quote=p fandango;337524]you might get away with upping to blues without a remap, but greens i think is pushing it too far[/quote]
my car is remapped
Post 337529 by p fandango on 2010-10-10 18:59:40
[quote=leighkaicraigmia;337525]my car is remapped[/quote]
for green injectors?
Post 337532 by T5frankie on 2010-10-10 19:09:48
[quote=p fandango;337529]for green injectors?[/quote]
i have a 304 remap and a mbc which i want to push up to 18psi maybe more can i not just put the greens in as it is or will the map need custom tuning for them?
same question for blues?
Post 337534 by p fandango on 2010-10-10 19:15:15
the ECU has quite a bit of in-built adaption & MAY have enough to cope with the blues, i know some people have swopped to bigger injectors & been fine while others have had it throw up codes so theirs no guarantees
Post 338322 by streaky744 on 2010-10-14 23:50:28
so why does my c70 have blue injectors and its standard or is that the case with me7's?
Post 338327 by p fandango on 2010-10-15 00:28:35
[quote=streaky744;338322]so why does my c70 have blue injectors and its standard or is that the case with me7's?[/quote]
yep according to my list the C70 changed from white to blues in 1999, which ties in nicely with the introduction of ME7
Post 338399 by T5frankie on 2010-10-15 16:39:16
funny thing is i have just bought a set of blues that came off a 1998 c70 t5 thats why i was confused, how easy are they to fit mate?
Post 338411 by p fandango on 2010-10-15 17:20:40
[quote=leighkaicraigmia;338399]funny thing is i have just bought a set of blues that came off a 1998 c70 t5 thats why i was confused, how easy are they to fit mate?[/quote]
although it's registered 1998 it might be a 1999 manufacture year (ie ME7).
its quite easy, undo the pipes into the fuel rail, 2 bolts hold the rail to the manifold & pull
Post 338416 by T5frankie on 2010-10-15 17:39:02
[quote=p fandango;338411]although it's registered 1998 it might be a 1999 manufacture year (ie ME7).
its quite easy, undo the pipes into the fuel rail, 2 bolts hold the rail to the manifold & pull[/quote]
what and the injectors come out with the rail?
Post 338421 by p fandango on 2010-10-15 18:04:01
[quote=leighkaicraigmia;338416]what and the injectors come out with the rail?[/quote]
yep, they only push fit then so either be stuck in the manifold or in the fuel rail
Post 338422 by T5frankie on 2010-10-15 18:05:51
think i'm gonna send them off for cleaning
Post 339836 by Alan M on 2010-10-22 19:13:11
Your ECU will throw up fuel trim codes mainly at part throttle with greens. Whites in your car currently are 0 280 155 766 flow 347cc@3 bar rail pressure and 16 ohm impedance. Blues are 0 280 155 830 347cc@ 3 bar rail pressure and 12 ohm impedance. Greens are 0 280 155 968 412cc@ 3 bar rail pressure and 12 ohm impedance.
