Post 337638 by dave854 on 2010-10-11 14:16:57
Has anyone had any experiance of repairing holes in the plastic bumper covers on the 70's? I've got one that looks like its met a towbar or something. Obviously the damaged section will have to be cut out but was wondering what the best option is to repair? Fibre glass, other resin stuff or cut in a section cut out of another bumper? Bumper needs a respray anyway so not fussed about making a mess repairing it.
Damage is in the centre just above the number plate... normally I'd just get another one from the scappy but its an R one :)
Will get a pic up later
Thanks in advance
Post 337684 by Tomcat on 2010-10-11 20:02:51
Depends how bad the damage is, you can remove the bumper cover, using a hot air gun (carefully), heat up the damaged section and push it back into place, if you do it right you can melt the edges enough to join it back together, failing that use a soldering iron to melt the edges back together. Don't use fibreglass as it wont bond well enough to last.
Post 337715 by dave854 on 2010-10-11 22:19:02
Ok, no to fibre glass then. will need some filling as there is a bit missing, will have a trawl through google and see what comes up.
Post 337737 by Tomcat on 2010-10-12 06:35:28
Once you've got the piece sorted you can fill the damage with flexible filler, don't use normal stuff as it will just crack.
Post 337776 by dave854 on 2010-10-12 13:01:13
picture of the damage (thanks to Gary for the pic)
I was thinking to cut the damaged bit out as its a bit buggered now although may go back to shape with heat as above, and then fix in somehow (plastic weld?) a new section from another bumper, about 6-10inches worth of the top surface and the front top corner so I don't have to rebuild the front edge and groove that runs round - hope that makes sense. Not yet had chance to look into it but will look at flexible fillers now, thanks Tomcat :)
Post 337793 by wegal on 2010-10-12 16:55:28
Id take the bumper off and fix wire mesh to the back then use flexible fillers to fill, use a fine wire mesh, bond it on with araldite or similar. Then the filler has a strong backing and wont just fall out over the first pot hole.
Post 337834 by Tomcat on 2010-10-12 19:56:27
[quote=dave854;337776]picture of the damage (thanks to Gary for the pic)
I was thinking to cut the damaged bit out as its a bit buggered now although may go back to shape with heat as above, and then fix in somehow (plastic weld?) a new section from another bumper, about 6-10inches worth of the top surface and the front top corner so I don't have to rebuild the front edge and groove that runs round - hope that makes sense. Not yet had chance to look into it but will look at flexible fillers now, thanks Tomcat :)[/quote]
I have a section from an R front bumper (the top part as it happens) lying around in the garage, I could cut you a piece of to weld in if you like.
Post 337853 by dave854 on 2010-10-12 20:24:32
got to ask Tomcat... what happened to the rest of it?! a section would be handy though...
Post 337884 by Tomcat on 2010-10-12 21:20:35
[quote=dave854;337853]got to ask Tomcat... what happened to the rest of it?! a section would be handy though...[/quote]
It ended up here...lol. Pm me your address and I'll sort you a piece out (it may get to the weekend before I can post it though).
Post 337895 by dave854 on 2010-10-12 22:01:13
that is COOL!!! some dedication there! How did you join the two parts? will PM address in a bit...
Post 337899 by Tomcat on 2010-10-12 22:14:11
The two parts where just plastic welded together with a soldering iron, then I filled, sanded etc and then took a mould from it and made a new one out of fibreglass.
Post 338138 by dave854 on 2010-10-14 15:07:26
section needed... (Tomcat)
Post 338374 by dave854 on 2010-10-15 15:01:02
ok, the bumper might be up for grabs if I can't find anyone locally to sort the repair - I'm going to give my self a couple of weeks to find someone.
Two questions:
1- Does anyone on here know of a 'plastic welding' company or a decent body shop that does plastic repairs?
2- Would anyone on here be interested in it if I decide that I don't have the time etc etc? Drop me a PM if you are.
Post 355544 by dave854 on 2011-01-17 14:07:45
Still after a bit for the bumper :) have you still got that bit knocking about Tomcat? Hoping to get it done before the summer. If anyone is close to Sudbury (Suffolk) I don't mind coming and picking a bit up, I'll take a complete cover if someone wants to get shot of one?! Thanks
Post 355555 by Tomcat on 2011-01-17 16:18:17
Reallysorry about that, still got it, I'll go have a root around the shed in the morning for you.
