Remote dash led
Post 340716 by willi on 2010-10-26 19:50:47
Has anyone had this problem?? After unlocking the v70tdi with the remote,i get into the car and then put the key in the ignition and start the car. The dash led flashes quickly for about 10 secs then stops.Otherwise the locking system works fine. Any ideas please.
Post 340717 by PHIL V70R on 2010-10-26 20:01:51
[quote=willi;340716]Has anyone had this problem?? After unlocking the v70tdi with the remote,i get into the car and then put the key in the ignition and start the car. The dash led flashes quickly for about 10 secs then stops.Otherwise the locking system works fine. Any ideas please.[/quote] could poss think you are breaking in 2 it or ultrasonics switching of...lol..not sure but thats what happend 2 me+low battrey in the fob..may be..:P
Post 340719 by Cubes on 2010-10-26 20:11:05
It's a fault with the alarm system mate. Needs plugging in to VADIS. I had the same problem 2 months ago. It said the system was fine though and it seemed to reset itself.
Post 340721 by willi on 2010-10-26 20:56:09
[quote=Cubes;340719]It's a fault with the alarm system mate. Needs plugging in to VADIS. I had the same problem 2 months ago. It said the system was fine though and it seemed to reset itself.[/quote] Would disconnecting the battery for a few hours sort it do you think??
Post 340782 by Cubes on 2010-10-27 13:28:54
It's worth a try. Mine started to flash after I disconnected the stereo, which is a bit random! Speaking of which, if you do disconnect the battery make sure you have your stereo PIN first! If you read this too late your main stealer can provide you witht he code if you pop down with your V5 doc. Let me know if it works!
Post 340816 by willi on 2010-10-27 17:22:04
[quote=Cubes;340782]It's worth a try. Mine started to flash after I disconnected the stereo, which is a bit random! Speaking of which, if you do disconnect the battery make sure you have your stereo PIN first! If you read this too late your main stealer can provide you witht he code if you pop down with your V5 doc. Let me know if it works![/quote] I diisconnected the battery for 2 hours after lunch and as a result it has corrected the problem. Many thanks
Post 340831 by Cubes on 2010-10-27 19:05:25
Weird! Good news though!
