VOC Meeting Crief 31st Oct 2010
Post 341691 by t5_monkey on 2010-10-31 20:54:45
Some picces from the VOC meeting today - was good fun. Important Note = all number plates should be obscured, sometimes Photobucket has a short delay on modifications you've made going 'live' so if you see your or another plate, it has been distorted and will be obscured shortly :) Image Image Image Image Image Image Image Image Image Image Image Image
Post 341692 by t5_monkey on 2010-10-31 20:55:25
Post 341693 by t5_monkey on 2010-10-31 20:55:57
Post 341699 by smithy on 2010-10-31 21:29:57
looks like a good meet mate nice pics
Post 341715 by si850r on 2010-10-31 22:36:08
nice.........very nice
Post 341745 by p fandango on 2010-11-01 01:07:58
an 850 Turbo, now thats an early one :jaw: (with 1995 spec rear lights & boot panel)
Post 341774 by y2blade on 2010-11-01 10:28:56
great pictures :) looks like a good meet-up
Post 341816 by DuncVolvoTurbo on 2010-11-01 16:48:11
[quote=p fandango;341745]an 850 Turbo, now thats an early one :jaw: (with 1995 spec rear lights & boot panel)[/quote] Aye, that'll be mine then :D
Post 341822 by y2blade on 2010-11-01 17:02:53
[quote=DuncVolvoTurbo;341816]Aye, that'll be mine then :D[/quote] hey Duncan :) good to see you on here, Thought I recognised that car from the picture
Post 341826 by DuncVolvoTurbo on 2010-11-01 17:10:07
[quote=y2blade;341822]hey Duncan :) good to see you on here, Thought I recognised that car from the picture[/quote] Yeah, been here for a wee while, not as long as yourself though! Hope your T5 is running ok, and the Alpine is still up to scratch.
Post 341827 by p fandango on 2010-11-01 17:11:55
[quote=DuncVolvoTurbo;341816]Aye, that'll be mine then :D[/quote] & also with the Volvo RIP kit as standard :partysmil
Post 341830 by y2blade on 2010-11-01 17:15:13
[quote=DuncVolvoTurbo;341826]Yeah, been here for a wee while, not as long as yourself though! Hope your T5 is running ok, and the Alpine is still up to scratch.[/quote] yes mate all good with the T5 thanks....and the Alpine is still going strong :cool: I also have a D5 too for commuting in now
Post 341831 by DuncVolvoTurbo on 2010-11-01 17:15:29
[quote=p fandango;341827]& also with the Volvo RIP kit as standard :partysmil[/quote] Of course ;) although it now has silicone hoses to replace the standard Volvo rubber ones.
Post 341833 by DuncVolvoTurbo on 2010-11-01 17:18:29
[quote=y2blade;341830]yes mate all good with the T5 thanks....and the Alpine is still going strong :cool: I also have a D5 too for commuting in now[/quote] A secretly fancy a D5 too :D
Post 341836 by p fandango on 2010-11-01 17:24:25
[quote=DuncVolvoTurbo;341831]Of course ;) although it now has silicone hoses to replace the standard Volvo rubber ones.[/quote] & still got the heater element as well, goes around the spark plugs under the plastic cover
Post 341837 by DuncVolvoTurbo on 2010-11-01 17:28:48
[quote=p fandango;341836]& still got the heater element as well, goes around the spark plugs under the plastic cover[/quote] Ah, you got me there! But if you say it's there, as we have nearly identical cars (well they were when they left the factory), then it still will be. :D
Post 341846 by p fandango on 2010-11-01 18:01:19
[quote=DuncVolvoTurbo;341837]Ah, you got me there! But if you say it's there, as we have nearly identical cars (well they were when they left the factory), then it still will be. :D[/quote] coming out from under the plastic spark plug cover just by the HT leads will be 2 metals pipes with vac hose connected, one goes to the vac tree & think the other went to the intake on BT. It was part of the recall to try & cure the throttle freezing (which was never a problem to us) before they dropped the RIP. Its a metal pipe thats routed around the spark plugs to transfer the heat from the cylinder head & warm the air in the pipes up BT was badged as a T-5 but called "turbo" on the V5, so the next phase after yours but earlier than most (she had the Volvo RIP as well). Yours does look exactly as BT was when i bought her, only she was never that clean lol
Post 341849 by DuncVolvoTurbo on 2010-11-01 18:16:32
[quote=p fandango;341846]coming out from under the plastic spark plug cover just by the HT leads will be 2 metals pipes with vac hose connected, one goes to the vac tree & think the other went to the intake on BT. It was part of the recall to try & cure the throttle freezing (which was never a problem to us) before they dropped the RIP. Its a metal pipe thats routed around the spark plugs to transfer the heat from the cylinder head & warm the air in the pipes up BT was badged as a T-5 but called "turbo" on the V5, so the next phase after yours but earlier than most (she had the Volvo RIP as well). Yours does look exactly as BT was when i bought her, only she was never that clean lol[/quote] I do think it has the pipes......never knew what they were though! Mine was badged as a T-5 as well (I think all the UK Turbos were), I just wanted my car to be badged as what it actually is, so got a proper badge from the States. That silver 855 in the pics is also a Turbo, but badged as a T-5 too and will a much lower spec (which is weird as the Turbo was the highest spec 850 you could buy at the time).
Post 341856 by p fandango on 2010-11-01 18:25:13
[quote=DuncVolvoTurbo;341849]Mine was badged as a T-5 as well (I think all the UK Turbos were), I just wanted my car to be badged as what it actually is, so got a proper badge from the States. That silver 855 in the pics is also a Turbo, but badged as a T-5 too and will a much lower spec (which is weird as the Turbo was the highest spec 850 you could buy at the time).[/quote] ah yes so she's identicle to BT then. You seem to know alot about the names & badging, did Volvo sell any T-5R's as "850 plus 5's", did they change them after the brochure or State versions only because i've never seen one LINK
Post 341858 by DuncVolvoTurbo on 2010-11-01 18:36:47
[quote=p fandango;341856]ah yes so she's identicle to BT then. You seem to know alot about the names & badging, did Volvo sell any T-5R's as "850 plus 5's", did they change them after the brochure or State versions only because i've never seen one LINK[/quote] Not so much, I just seem to know a lot about things that aren't that important to anyone else! lol I have never seen that press release before, but I have heard rumours of the Plus 5. The only thing I can think of, and this will probably be completely wrong, is that they were going to call the car the Plus 5 but then changed their minds before actual production to make it the T-5R. The thing that seems a bit odd is that they state it was only going to be produced in a saloon version. Was the original BTCC car going to be a saloon, but after some testing they found the estate worked better, and so had to make a production version (and scrapping the Plus 5 name)? I honestly don't know, and I am just rambling but it would be good to find out. I might just use my special VOC hat to get some info out of Volvo themselves!
Post 341865 by p fandango on 2010-11-01 19:05:16
[quote=DuncVolvoTurbo;341858]I have never seen that press release before, but I have heard rumours of the Plus 5. The only thing I can think of, and this will probably be completely wrong, is that they were going to call the car the Plus 5 but then changed their minds before actual production to make it the T-5R. The thing that seems a bit odd is that they state it was only going to be produced in a saloon version. Was the original BTCC car going to be a saloon, but after some testing they found the estate worked better, and so had to make a production version (and scrapping the Plus 5 name)? I honestly don't know, and I am just rambling but it would be good to find out. I might just use my special VOC hat to get some info out of Volvo themselves![/quote] tbh i probably robbed that press release from VOC lol. I've heard many different stories behind the BTCC project, one being both saloon & estate were tested & with not much performance difference they went with the estate for the PR, i've only ever seen Big Red as the original prototype never seen a saloon version. Or that when SAM went to pick up the shell for the prototype only estates were available. The BTCC car is based on the 2.0 GLT so no need for a special edition to use either the saloon or estate, inless you were going to cheat like Alfa lol another difference between the plus 5 & the T-5R is the plus 5 says leather interior, while the T-5R is leather & alcantara Image
Post 341975 by gmain1967 on 2010-11-01 22:37:23
[quote=DuncVolvoTurbo;341858]The thing that seems a bit odd is that they state it was only going to be produced in a saloon version. Was the original BTCC car going to be a saloon, but after some testing they found the estate worked better, and so had to make a production version (and scrapping the Plus 5 name)? I honestly don't know, and I am just rambling but it would be good to find out. I might just use my special VOC hat to get some info out of Volvo themselves![/quote] I'm in at Clelands on Wednesday to get standard wheel bolts to replace the locking ones which I don't think will last much longer (Dunc can vouch for this!), so I'll ask Mr Cleland if he knows what the story was with it. Not what you know, but who you know!!! Cheers
Post 342071 by LiamT4 on 2010-11-02 16:47:29
Some very nice cars there, good pics to.:B_thumb:
Post 343276 by JelT5 on 2010-11-08 16:39:03
Great pics T5monkey, looked like a good meet. Thanks for posting mate :)
