Post 32019 by Simh on 2005-07-16 09:15:58
Hi All
Can anybody tell me what the stud pattern measurements would be for my V70 T5 Reg 2001. I have seen a set of wheel Stud pattern: 5 x 108 mm Wheel size: 18 x 8 they have come off a 2004 Volvo (not sure which model)
Could you also give me some idea what size rubber I should run on theses rims?
Post 32037 by dave on 2005-07-16 10:41:22
there off s60r/v70r i think!
my car is a standard s60r, the standard tyres that came with it, were 235/40/18
im sure you could fit some different sizes on that rim
dave
Post 32038 by andi t5 on 2005-07-16 10:43:57
[QUOTE=Simh]Hi All
Could you also give me some idea what size rubber I should run on theses rims?[/QUOTE] wouldnt the obvious thing to do be to take a wheel off and try your new one?
Post 32040 by Simh on 2005-07-16 10:59:18
Yeah that would be the way to do it if I was in the same place as the wheels. :dunce:
Post 32041 by Simh on 2005-07-16 11:02:07
Yeah that would be the way to do it if I was in the same place as the wheels. :haha:
Post 32042 by rottertron on 2005-07-16 11:02:39
What size wheels and tyres have you currently got?
Then you can work out the rolling circumfrence of the original tyres compared to the new ones you plan to fit, as this will affect your speedo and gearing.
Post 32043 by rottertron on 2005-07-16 11:06:03
Check out this link for help
[SIZE=3][COLOR=DarkRed]Tyre Calculator [/COLOR][/SIZE]
Post 32045 by andi t5 on 2005-07-16 11:30:33
[QUOTE=Simh]Yeah that would be the way to do it if I was in the same place as the wheels. :haha:[/QUOTE]then just mesure the stud spacing on your car, hardly rocket science is it? (you will however need to obtain a metric rule first)
Post 32048 by dave on 2005-07-16 12:48:13
alright, give the guy a break!
lets be a nice!
Post 32057 by Simh on 2005-07-16 13:59:40
Andi T5 I always enjoy the most practical advise you offer.
Post 32069 by k690bpp on 2005-07-16 16:14:02
they're pegs from the s60r or new v70r and they will 100% fit your v70 as they have the same stud pattern 5x108.
235/40-18's are fitted as standards but these rub on older s70's and s1 v70's so the best tyre on these is usually a 225/35-18 but seeing as you've got a s2 v70 the standard 235/40-18 should be ok but check here first:
http://www.miata.net/garage/tirecalc.html
put in your own standard tyre size and experiment to get the closest match.
go on get them on they look great, heres my s70r with them on:
http://uk.geocities.com/whsuk/s70r/QV003.jpg
Post 32071 by TangoDeltaSierra3 on 2005-07-16 16:34:30
So is it better to be - %2 differencr or + %1.7 - or is there hardly any difference ?
Post 32073 by k690bpp on 2005-07-16 17:22:11
upto a 3% difference smaller or larger is ok
