Post 344332 by BruceT on 2010-11-13 21:36:16
Ive just bought a 2000 X V70 Phase 2 2.3 T5.
What diagnostics does it use, OBDII, Canbus etc?
Can anyone recommend a code reader under £100 to read and clear codes?
I understand the ABS and SRS usually require more expensive tools?
Does the ELM327 and Windows 7 Laptop work with a 2000 P2 V70 T5?
Post 344379 by p fandango on 2010-11-14 08:56:52
its OBDII mate, i bought a £20 OBDII to USB from fleebay, got the free software with it that can read the engine codes. As you say you need the dearer stuff to read airbag & other bits but just for engine faults its fine, i've even used it to reset the engine code on a mates Merc so comes in quite handy
Post 344527 by BruceT on 2010-11-14 21:30:55
Will this reset the abs service light?
http://www.talktomycar.co.uk/products/advcode/mj092.htm
