This doesn't look good
Post 347034 by Mart501 on 2010-11-24 22:32:50
I'm pretty sure this is not good, but what could be the cause and consequences of this. The clip was lose enough that the pipe could be removed which I did to clean the oil off and refit and tighten the clip. Image
Post 347051 by p fandango on 2010-11-25 00:04:17
that looks like a boost pipe so should be alright now you've tightened it, was it running lumpy or anything before? What model is it?
Post 347053 by The Flying Moose on 2010-11-25 00:10:15
Looks like an S40 to me though may be wrong. Definately a boost pipe. Just residual oil from the turbo.
Post 347061 by Mart501 on 2010-11-25 00:23:52
sorry should have given you a clue, its a '01 V40 T4. Not lumpy but I had noticed a bit of turbo whoosh after I fitted the boost gauge so thought I had a slight leak in the vacuum pipe, while sealing that I noticed it but not been for a drive yet
Post 347065 by The Flying Moose on 2010-11-25 00:28:01
[quote=Mart501;347061]sorry should have given you a clue, its a '01 V40 T4. Not lumpy but I had noticed a bit of turbo whoosh after I fitted the boost gauge so thought I had a slight leak in the vacuum pipe, while sealing that I noticed it but not been for a drive yet[/quote] Haha wasnt far off with a guess at an S40 then! Good job you spotted it as if you have never had a boost hose blow off its a horrid experience and may leave you puzzled whats happened. Thankfully you spotted it and tightened it up. Its worth checking the other hoses too if this one worked its way loose.
