Bloody crappy oil seals
Post 352771 by Dangerous Dave on 2010-12-31 20:50:22
I'm raging at the moment. Today I took delivery of my camshaft oil seals (after the engine unloaded all of its oil last week and with it being christmas getting new ones would take a while). So out I went and removed the camshaft sprockets and replaced the bad seal with one of the new ones, no problem. Then I took the other cam seal out, and tried to fit the other new seal. No such bloody luck. Checking the seal size against the old one it was a fraction larger and wouldn't go in no matter what I tried, the part numbers were the same on both the new packets (the wrong seal packet was different though and had 'made in taiwan' on it and also had a scamtech 'certificate of quality' inside it), bloody scamtech crap. So now I've got to get another seal so it will be another week at least as no one will be in until Tuesday. AAAARRRRGHHHH Dammit. So back into my dad's volvo for the next week or so Rant over LOL On the plus side I changed my thermostat and one of the intake hoses, so at least I got something done.
Post 352774 by mark_eire on 2010-12-31 21:10:47
Ahhh no abseloute nightmare!! is there not a volvo garage local to you?
Post 352775 by Volvostorm on 2010-12-31 21:15:17
Either I've been lucky, but my volvo dealers has always got parts like seals in the next day, longest I've had to wait is 4 days for my R clutch from Sweden. They were often cheaper than aftermarket parts too. Have you found out why it pushed the seals out in the first place?
Post 352781 by Dangerous Dave on 2010-12-31 22:16:55
[quote=mark_eire;352774]is there not a volvo garage local to you?[/quote] Yeah, theres one not far from me, so might be able to get one on Tuesday. [quote=Pault5estate;352775]Have you found out why it pushed the seals out in the first place?[/quote] I've checked the PCV system and all is ok, the old seal was also a pattern part from when I did my headgasket a couple of years ago, it was quite loose in its seat and all the inside of the seal had worn away, so I guess it just worked its way out with help from the oil pressure and the camshaft turning. Think its been leaking a tiny bit for a while, but hadn't thought to check the seals.
