Help
Post 353617 by jedi123 on 2011-01-07 00:23:27
Hi guys I need some advice please. I own a C70 t5 2000 model and I have just started having intermitent non start problems. I do know that the throttle body is faulty but I want to know if it would stop the car from starting. Any advice would be appreciated.
Post 353621 by p fandango on 2011-01-07 04:33:43
on ME7 cars (which yours is) the ECU controls the throttle body as part of the choke/cold start so could well be the problem. Does it idle ok once started?
Post 353625 by jedi123 on 2011-01-07 08:19:28
[quote=p fandango;353621]on ME7 cars (which yours is) the ECU controls the throttle body as part of the choke/cold start so could well be the problem. Does it idle ok once started?[/quote] It idles fine when running. What happens is I can start the car then instantly it cuts out then it wont start if I leave it a few minutes it starts up ok but it did take a good 10 minutes a couple of days ago. Do they suffer from fuel pumps.
