Post 355062 by volvo-tom on 2011-01-14 16:39:09
i bort this the other day, - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140497967489 (ive also bort my self a small universal tank)
it arrived in the post today & ive bin looking through the kit and it looks really good for the money! im fitting it to my 480 turbo tommorow with my mate daz and just wondered if anyones used methanol/water injection before?
will keep updated with install pics asap,
tom
Post 355092 by Alan M on 2011-01-14 18:37:50
You bought a very good robust systems. Run a good pressure switch and the systems work very well. I run a 50/50 mix. My car does like 100% methanol and my pressure switch activates at 10psi. I did have it lower but the best results on the dyno showed 100% methanol coming in at 10psi with a K24 with a 0.5mm jet on my particular setup. Its worth investing in some dyno time once your car is setup so you can see where best to bring in the WI. Every car is different so get the kit up and running and then fine tune to your engines requirements. Make sure you use an inline non return valve to prevent auto syphoning under vacuum.
Post 355098 by Jamest5r on 2011-01-14 18:47:24
He's only about 16 Alan, it's how the youf spk innit mate.
Post 355099 by p fandango on 2011-01-14 18:49:09
& please use better connectors than the scotch locks it looks like they supply with it
Post 355123 by Alan M on 2011-01-14 20:11:45
Sorry lol. Devils own offer a progressive controller also that is a great unit. I have seen one being used very well in a Sierra Cosworth in conjuction with a fully mapable standalone ECU and the results with and without the WI in use were very noticeable on a dyno. Airflow is very poor on a dyno and the WI may compensate somewhat on it but results on the road bum dyno seem to like the use of WI on my car and my friends running Devils own WI systems.
Post 355195 by cherry1809 on 2011-01-15 11:14:53
[quote=volvo-tom;355062]i bort this the other day, - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140497967489 (ive also bort my self a small universal tank)
tom[/quote]
Keep us posted on the results :)
