Help with tyre probs?!
Post 3531 by dannt5 on 2004-12-05 21:58:10
Hi all,Does anyone elts have problems with tyres wearing very badly on the inside&outside edges(leaving the middle with 2-3mm tread left),fronts&rears in less than 3000miles? I have had the track rods,lower arms,shocks all replaced with volvo parts & its still the same.Im running 205x40x17s on my 850 t5 estate.Ive had all sorts of tyre makes,pirrelli,michelins,goodyear,fulda,bf,yokos+++ & they all do the same within 2-3000miles,the car does get used as it should be but im running out of ideas,not to mention money!! Help????
Post 3535 by Wobbly Dave on 2004-12-05 23:43:34
:welcome: Silly question - but have you had the tracking done?
Post 3538 by Justin on 2004-12-05 23:50:57
Its the camber alignment thats out, i take it your car came with 16" alloys from new, by adding 17" the tyres are not completely flat on the road as they are bigger and wear the edges, a decent mechanic should be able to sort it! ;)
Post 3540 by GuyD5 on 2004-12-05 23:54:23
and last but not least, wear on both edges is also a classic sign of under-inflation, what pressures were/are you running the tyres at? :)
Post 3562 by dannt5 on 2004-12-06 20:11:51
Hi,the trackings spot on,ive tried a selection of pressures from 32-38psi & had the camber checked.The wheels are genuine volvo ones from a V70T5R so the fitment should be spot on.My local tyre firm tells me its nothing more than exessive speed on corners,if this is so i cant be the only person with a t5 having this prob?
Post 3566 by Justin on 2004-12-06 21:38:11
Who checked the camber ?
Post 3651 by Bracer on 2004-12-08 08:39:20
[QUOTE=dannt5]Hi,the trackings spot on,ive tried a selection of pressures from 32-38psi & had the camber checked.The wheels are genuine volvo ones from a V70T5R so the fitment should be spot on.My local tyre firm tells me its nothing more than exessive speed on corners,if this is so i cant be the only person with a t5 having this prob?[/QUOTE] I would say you are probably scrubbing the tyres due to over inflation and reduced grip. Do you carry allot of heavy loads ? if not then you are way too high on the psi. Spec: Pressures from cold Up to 3 persons Saloon: F 32 / R 29 Estate: F 32 / R 30 Fully laden Saloon: F 33 / R 36 Estate: F 35 / R 41 I run my 215x45x17's Saloon F32 / R29 and have no feathering problems. Give it a try it might help :wink:
Post 3733 by dannt5 on 2004-12-09 22:03:55
Hi,volvo checked the camber settings.I dont carry any loads & hardly every have more than 2 people in car.Ive ran at 32psi all round with 1 set of tyres,1set at 34psi,another at the standard settings as on the fuel flap & almost every combination i can think of but they still wear the edges.Ive tried just about every logical thing to cure it & am running out of ideas,is there anybody elts that has the same prob??
Post 3734 by Murphy on 2004-12-09 22:20:28
Has the car been involved in an accident at all ?
Post 3767 by Markzx on 2004-12-10 12:53:57
[QUOTE=dannt5]Hi all,Does anyone elts have problems with tyres wearing very badly on the inside&outside edges(leaving the middle with 2-3mm tread left),fronts&rears in less than 3000miles? I have had the track rods,lower arms,shocks all replaced with volvo parts & its still the same.Im running 205x40x17s on my 850 t5 estate.Ive had all sorts of tyre makes,pirrelli,michelins,goodyear,fulda,bf,yokos+++ & they all do the same within 2-3000miles,the car does get used as it should be but im running out of ideas,not to mention money!! Help????[/QUOTE] I've had this on my 94 850 T5 Estate. I was running Perrelis P6000's on 17's and all I did to stop it was inflate tyres to 40psi. They wore evenly but if you ran over a mouse you could tell what Sex it was.
Post 3820 by dannt5 on 2004-12-13 20:04:18
Hi all,its never been in any kind of bump that i can tell of & i went to town on it when i was lucking to buy it.It drives/handles perfectly compaired to the last 2 t5s ive had & as well as my friends s60 t5.I did try the pressures at 40psi but it did tend to run on in bends badly & track the white lines so i changed them back after a day or so.My last 2 T5s scrubbed the edges on standard 205x50x16s but not as bad as this seems to on 17s.
Post 3931 by hamish on 2004-12-18 00:57:35
Dan, Have you replaced both halves of the front suspension top mounts ? Might be worth giing me a call at volvotuning. Regards, Hamish.
