Post 358083 by t5_monkey on 2011-02-03 20:30:20
My S40 T5 has developed a dead door.
Won't lock/unlock and window doesn't work (although I can still open it OK with the handle)
it's the passenger driver side - Any suggestions as to where to start troubleshooting this one?
Post 358098 by Chopster on 2011-02-03 21:27:27
The first thing I'd be checking is the multiplug that goes from the inside edge of the door into the B post
Post 358100 by t5 pete on 2011-02-03 21:43:48
If not the mullti plug ide take the door card off and look at the wireing make sure that the window mechanisim hasnt chewd any of them up
Post 358126 by wegal on 2011-02-03 22:27:36
Id start by checking the door....... sorry couldnt resist :-)
Post 358154 by t5_monkey on 2011-02-03 23:39:23
[quote=Porcine_Aviator;358149]Fuse? I know I know[/quote]
I think on the S40 one fuse runs both doors, so the driver door should be dead too if that were the case.
Will double check though :)
Post 358329 by T4FLY on 2011-02-04 22:59:53
Also have a check of the wires underneath the glovebox.
Post 358339 by Vikingxl on 2011-02-04 23:33:41
Weld it up dukes of hazzard style
Post 358432 by volvoboy2009 on 2011-02-05 16:53:07
volvo have a modifed wiring loom for this problem the looms get water in them but a top tip is if you cant open the doors at all take the wheel arch liner in question out and you will find some foam near the door remove this and waggle the wires then the door normally unlocks saves damaging anything
Post 358440 by MIKESC70T5 on 2011-02-05 17:29:22
It's not dead it's just sleeping
