Post 359873 by Steveh24 on 2011-02-11 19:11:16
I have a locking wheel bolt that won't budge, it was done up with an air gun by a gorilla
I broke the security socket trying to undo it, so I called the AA and the guy tried one of those impact tools but it broke 3 blades and he said he couldn't move it, so I took it to my Volvo dealer and the workshop tried and said they would either have to weld a standard bolt to it or drill it out, but it would have to be done as a chargeable job costing over £100.
So I got a local garage to try and remove it and they went for welding a bolt to it, but coz of the recess the weld wouldn't take that well and kept shearing off when torque was applied.
This is now becoming a right b@stard to remove, does anyone have any other suggestions or know of any specialists who can remove it, then I'm all ears
Steveh24
Post 359875 by p fandango on 2011-02-11 19:17:51
i'm afraid i had the same problem & had to cut my wheel off, even the local tyre shop with an air gun & specialist tool for removing locking wheel nuts wouldn't budge it
Post 359888 by claymore on 2011-02-11 19:39:52
yep same here, i tried welding a bolt on, but in the end I had to cut the wheel off.
Post 359893 by t5 stealth on 2011-02-11 19:49:48
iv got the nut removal sockets,but you need an air gun to use them.
iv had 100 % success with them,other people havnt lol.
where abouts are you based.
Post 359905 by Vikingxl on 2011-02-11 20:11:30
This is quite common problem and most people seem to overcome it Pedro is just a violent hooligan that wanted to chop an alloy up lol
Post 359907 by Flatout Phil on 2011-02-11 20:13:06
[quote=Steveh24;359873]I have a locking wheel bolt that won't budge, it was done up with an air gun by a gorilla
Steveh24[/quote]
As a rule of thumb, if Volvo want £100 to drill it out, then an independent will charge about £60! That is probably a lot cheaper than a new alloy.
As for McGard locking wheel bolts, check out various threads by searching. Don't use locking nuts - they are a total waste of time.
Post 359924 by Jimmie on 2011-02-11 20:28:36
If your local dealer had any brains he would order in the locking wheel nut removal kit and get them off for you unless there just after your money!
Post 359939 by andyb1375 on 2011-02-11 20:49:40
Hello Buddy. The easiest way in to bang on a 12 point 17mm socket with a lump hammer. I have removed hundreds this way! and the most it will cost you is a new socket.
Not sure where you are but I would be happy to remove in for you
Post 359955 by tomtyres on 2011-02-11 21:13:20
I had the big flat faced lockers with the wiggly line cut out on my s70, I used a 24mm impact socket and a 7lb club hammer! Then a good twist with a cracker bar, and bobs your uncle!
Good luck mate! :)
Post 359957 by JUDGENINJA on 2011-02-11 21:16:03
I agree with above.. Used this method many times when working in a garage £60 earned for 5 mins work.
One imperial socket hammered into the locking nut..
If it costs you a socket and you still fail atleast you've tried
Post 359958 by tomtyres on 2011-02-11 21:19:30
And if your local to Medway in Kent, we'll have a go at it! :)
Post 359981 by jason850t5 on 2011-02-11 22:04:35
I agree with phil. Locking wheel bolts are a total waste of time and more hassle than they're worth. I've always used the method of hammering on a slightly smaller socket, with a good success rate.
