3.5mm jack - CD changer input
Post 362973 by S1mon on 2011-02-25 23:47:47
My ATR had a Pioneer bluetooth headunit in it and I used to play my iPhone through it...REALLY missing it!! I'd like to be able to do the same in the Volvo but would ideally like to retain the SC-900 headunit just for the OEM looks. My question is...Is there such a thing as a cable with a 3.5mm jack connector on end and the male connector for the 6CD input on the headunit the other? (I believe this to be called an 8 pin DIN connector??...could stand corrected though!) Thanks muchly for any help in advance guys!
Post 362979 by kee1173 on 2011-02-26 01:14:27
Check thru the threads on here, sure there was someone converting the old Volvo units fso you can use Ipods etc ... not sure about Jack plugs but was def someone converting them.... maybe of some help.. just look thru the search system on ice or items for sale...
Post 362992 by Yosser on 2011-02-26 10:19:44
The guy you need to ask is bobbych, he's done loads of work/research on this.
