Post 377393 by leet5r on 2011-05-11 22:02:01
any 1 know the easyest way on how to change the front wheel bearings cheers
[quote=leet5r;377393]any 1 know the easyest way on how to change the front wheel bearings[/quote]
you have to change the whole hub i believe
Yeah, you do, undo cv nut, and remove joint, your have to undo the ball joint, then unbolt the hub from behind, and refit the new one.
4 large female torx bolts on the back securing the hub. Help in place with thread lock. Best way is with air tools as they are very tight. Either air or a 1/2" breaker bar & some sweat for good measure.
i'm looking into fitting XC90 hubs, really could do with an old one to measure see if the bolt patterns the same
