Cambelt
Post 377695 by Mongo on 2011-05-13 15:16:32
Hi all just wonderd how easy it is to do a t5 cambelt? Has anyone got any tips on marks and stuff? Engines out the car to wich makes life easier. All tips would be brilliant thanks
Post 377740 by manback on 2011-05-13 18:05:29
Easy! Remove the tensioner from the wheel arch. Change the belt, put the tensioner in the vice close it up, put a nail in to keep it compressed. Put the tensioner back in place and pull the nail out. Obviously timing needs to stay the same. The Haynes book of lies covers it pretty well.
Post 377742 by t5 stealth on 2011-05-13 18:27:35
its quite an easy job if you know what your doing, could be a dissaster if you dont. pics show how belt should look, and pic of tensioner,with pin in position, squeeze the tensioner back very slowly with light pressure,dont force it back or you will damage it, not very good pics,but hopefully you can see.... someone must have better pics....most likely the forum picture whore....mr fandango :)
Post 377750 by manback on 2011-05-13 18:41:47
Your right. Before you begin work find tdc on the crank pulley. Then make sure the Mark on the cams line up b4 you remove the belt. Its possible to remove the cam shafts from the cogs. Mine were no where near the marks!
Post 377778 by Tomcat on 2011-05-13 20:17:12
Hardest parts are seeing the bloody timing mark on the crank pulley (as it's barely a scratch on one of the teeth) and getting the sodding belt over the stupid protrusion behind the crank pulley, other than that it's a doddle.
Post 377797 by Mongo on 2011-05-13 21:00:52
Thankyou all for your tips ill give it a go iv got haynes manuel just in case i get massivly stuck. Thanks all
Post 377804 by t5 stealth on 2011-05-13 21:08:55
just dont turn the key until your sure its all correct and tight, and double check or your next thread you post will be about how to and how much to remove head and relace 20 valves :)
Post 377841 by Tomcat on 2011-05-13 21:46:49
Once the belts back on rotate the engine over a few times with a wratchet on the crank pulley, that way you can double check the belt tensions and that nothing is hitting, then you can re-align the timing marks and check everything's as it should be, then start it up.
