making your own rip kit
Post 378593 by stevie69 on 2011-05-17 21:33:09
iv got myself some 60mm pipe so was wondering if anyone knows the sizes ill need for the silicone joints?the size on top of the turbo,top intercooler,throttle body,and bottom intercooler.also do you put a bit on the bottom pipe so you can connect to the idle control.iv been wanting to try it for ages but would like to have all the stuff ready.thanks..
Post 378608 by The Flying Moose on 2011-05-17 22:34:50
Hi Stevie, I have a list at home on my laptop after I made the last set. Ill post it up when I get home for you. As for the connector for the idle control valve yes you do need one. There are a few ways you can do this. Either weld an outlet to the pipework, cut into the silicone with a silicone valve or buy a ready made 60mm pipe with a T-piece already fitted.
Post 378840 by stu_850t5 on 2011-05-19 07:26:36
and where's P fandango?? missing out on a chance to post up pictures!
Post 378843 by JelT5 on 2011-05-19 07:38:25
[quote=stu_850t5;378840]and where's P fandango?? missing out on a chance to post up pictures![/quote] It won't be long before our resident picture ho posts something ;)
Post 378845 by JelT5 on 2011-05-19 07:40:15
[quote=stevie69;378593]iv got myself some 60mm pipe so was wondering if anyone knows the sizes ill need for the silicone joints?the size on top of the turbo,top intercooler,throttle body,and bottom intercooler.also do you put a bit on the bottom pipe so you can connect to the idle control.iv been wanting to try it for ages but would like to have all the stuff ready.thanks..[/quote] I can give you the size for the turbo (all I can remember, sorry) 50mm i/d.
Post 378846 by Flatout Phil on 2011-05-19 07:43:41
[quote=JelT5;378843]It won't be long before our resident picture ho posts something ;)[/quote] Jerry, I have been meaning to ask this for a while. Is there a particular reason why you have an aquatic bottom-feeder with a Volvo badge as your avatar??? Unless you like feeding on aquatic bottoms that is... Good luck with the day by the way.
Post 378852 by JelT5 on 2011-05-19 09:20:22
[quote=Flatout Phil;378846]Jerry, I have been meaning to ask this for a while. Is there a particular reason why you have an aquatic bottom-feeder with a Volvo badge as your avatar??? Unless you like feeding on aquatic bottoms that is... Good luck with the day by the way.[/quote] Volvo Turbot Phil ;) Will PM you regards today, been and come back home, very efficient the French health service!
Post 378864 by p fandango on 2011-05-19 12:23:45
[quote=stu_850t5;378840]and where's P fandango?? missing out on a chance to post up pictures![/quote] wow give me chance man, been working(ish) nights so have to sleep Image Image Image Image you will need a 19mm port welding into the last pipe for the idle control valve, can't remember the actual sizes needed for the ports as the info was on my old USB stick which got lost
Post 378875 by Flatout Phil on 2011-05-19 12:48:07
[quote=JelT5;378852]Volvo Turbot Phil ;) [/quote] Turbo-T! That is a bit too intellectual for me - you have been living in France TOO long! You will be quoting Foucault and Camus next!
Post 378878 by JelT5 on 2011-05-19 12:51:02
[quote=Flatout Phil;378875]You will be quoting Foucault and Camus next[/quote] Who???? I'll have to ask t'missus about they two boy ;) I'm just about ok with Alexandre Dumb-Ass :D Notice I didn't comment about the bottom feeding, a bit too close to home at the moment!!!
Post 378924 by The Flying Moose on 2011-05-19 18:17:51
Right found the list... this is what I used to make my list RIP kit. 1x 76-57mm Straight Reducer 3x 45 Degree 76mm Elbow 1x 76-51mm Straight Reducer 1x 90 Degree 76-63mm Elbow 1x 90 Degree 76-57mm Elbow 1x 90 Degree 76mm Elbow
Post 782123 by c70geoff on 2015-08-17 11:30:32
[QUOTE=The Flying Moose;378924]Right found the list... this is what I used to make my list RIP kit. 1x 76-57mm Straight Reducer 3x 45 Degree 76mm Elbow 1x 76-51mm Straight Reducer 1x 90 Degree 76-63mm Elbow 1x 90 Degree 76-57mm Elbow 1x 90 Degree 76mm Elbow[/QUOTE] which of these are alloy pipes or are they all silicon?
Post 782124 by p fandango on 2015-08-17 11:43:42
[QUOTE=c70geoff;782123]which of these are alloy pipes or are they all silicon?[/QUOTE] they are all silicone joints, the lengths of straight pipe you'll have to measure up & cut yourself. That list is to make a 76mm rip
Post 782153 by Ettienne on 2015-08-17 18:53:01
I've got a spare stainless 2.5 (63mm) lower rip pipe tig welded with dv and icv outlets I'll be popping on eBay. Nice fit too. I have a top pipe as well, which I may also pop on eBay, but it was a slightly odd fit as I made if out of off cuts, again stainless 2.5"
