Post 379556 by fyldetowbars on 2011-05-22 12:45:32
if i buy a varable boost valve will it increase my psi or just make it adjustable between 0-std ????
[quote=fyldetowbars;379556]if i buy a varable boost valve will it increase my psi or just make it adjustable between 0-std ????[/quote] it'll raise the boost over standard, with a stock map tho the ecu will limit boost to a maximum of about 15psi
it's only boosting about 9psi any how are they easy to fit and in your opinion which one is the way to go ???
[quote=fyldetowbars;379560]it's only boosting about 9psi any how are they easy to fit and in your opinion which one is the way to go ???[/quote] 9-10psi is about right for standard. As for which boost controller is best depends what your after, if you plan to do quite alot of mods then an electric boost controller will be best, other than that a decent MBC will make you smile
