New engine set backs
Post 380887 by Mongo on 2011-05-27 14:19:45
Hi all can anybody tell me were the cruise control is located on the 850 t5 and also what pipes go to it is there a vac pipe from the vac tree or throttle body? Ive put my new engine in seems to be ok just ranning a bit lumpy on tic over also the temp gauge when driving doesnt go over a 1/4 but after sitin on tic over for around 10 mins reaches 1/2 way but no fan is this normal? And finaly lol my boost is all over the place hits 0.7- bar but should be 1.2 on the rica ecu ive got. Dnt no why ill check for a leak but dnt think there is! Thanks for looking all. All answers apritiated!
Post 380910 by The Flying Moose on 2011-05-27 16:12:19
My thermostat rarely reaches over a third of the way up even after an hour idling. I would worry about that in the slightest. There are two types of thermostats for the 850 one opens sooner than the other. As for the fan I think mine has only ever come on after I have turned the car off. Wouldnt worry unless your temperature starts to hit the high end on the guage. As for your boost, if you dont have all the VAC lines connected you wont reach full boost as there will be a vacuum leak. This would also explain the erratic/lumpy running.
Post 380913 by p fandango on 2011-05-27 16:16:30
i'd certainly try & make sure the fan is working ok before you use it for any long journey's. There are 2 yellow wires from the ECU to the fan relays which will get the fan working if you bypass them to earth, i'll look on BT & get back to you with pics & the colours.
Post 380916 by Mongo on 2011-05-27 16:20:18
[quote=The Flying Moose;380910]My thermostat rarely reaches over a third of the way up even after an hour idling. I would worry about that in the slightest. There are two types of thermostats for the 850 one opens sooner than the other. As for the fan I think mine has only ever come on after I have turned the car off. Wouldnt worry unless your temperature starts to hit the high end on the guage. As for your boost, if you dont have all the VAC lines connected you wont reach full boost as there will be a vacuum leak. This would also explain the erratic/lumpy running.[/quote] Aw thanks for the tempreture input. Can you please tell me what should run off the 3 vac connectors on the throttle body and off the tree.? At the minit iv got dump valve, fan and 1 blank and servo off the big one on the throttle body and on the tree just my fuel reg vac i think. Does cruise control need to go on the vac tree/throttle body? And am i missing anthing? Thanks
Post 380918 by woody on 2011-05-27 16:21:23
When I was getting my car Rica'd by HLM, I was strongly advised to change my thermostat asap as it was sitting at a 1/4! They said it was early sign of failure. I changed it with a genuine replacment and it now sits at the half way point all year round!
Post 380933 by Mongo on 2011-05-27 16:53:09
Aw thanks people ill put my spare one in then that seemed ok before i swaped engines thanks agen
Post 380949 by Mongo on 2011-05-27 18:21:30
Does any body no what vacume pipes go were im not sure if im missing one iv rit a post above with wot pipes ive got a nd were they go. Thanks
Post 380979 by Mongo on 2011-05-27 19:41:54
Has anybody got a vacume diagram and a cruise control diagram and locotion of were it is? Thanks
Post 380998 by The Flying Moose on 2011-05-27 21:01:15
Here you go mate.
Post 381148 by Mongo on 2011-05-28 11:39:35
Thanks for the diagram mate but still dont show what was on there ive got 3 conectors for vacs on the intake manifold two used by dump valve and fan, the 3rd i dont no iv bloked off myself for now. Then on the vac tree got fuel reg vac. Any ideas please cos its a bit lumpy on tik over. Thanks
Post 381270 by The Flying Moose on 2011-05-28 20:40:41
The only thing I can suggest doing is trace all the VAC lines from the diagram to ensure they are all in the correct places, if everything is present just block the other outlets.
