Nivomat
Post 389082 by KARL on 2011-06-23 22:10:44
Hi All I read some were sometime ago you can confuse Nivomats to be set lower when trying to lower the cars ride hieght. I understand you have to change the normal front shocks, but want the rears to match without removing the perfectly working rear Niv`s ! Somthing to do with the level sensor/air pump bieng tricked about with !! Cheers
Post 389102 by fyldetowbars on 2011-06-23 22:59:27
just drop it ? i did
Post 389894 by KARL on 2011-06-26 22:21:17
[quote=fyldetowbars;389102]just drop it ? i did[/quote] What replace the Lot ?
Post 389897 by p fandango on 2011-06-26 22:24:53
if you change to non-nivomats you need to change the top rear shock mounts
Post 390100 by v70torslanda on 2011-06-27 21:22:53
Just to be clear. There is NO air pump There is NO level sensor You MAY be able to use a shorter spring on the rear and the suspension unit MAY not be able to work itself up to its full ride height. Or it might. In which case you'll have the 'arse in the air' syndrome, which isn't pretty . . .
Post 392672 by KARL on 2011-07-06 19:12:59
[quote=v70torslanda;390100]Just to be clear. There is NO air pump There is NO level sensor You MAY be able to use a shorter spring on the rear and the suspension unit MAY not be able to work itself up to its full ride height. Or it might. In which case you'll have the 'arse in the air' syndrome, which isn't pretty . . .[/quote] You telling me ! Lol Thanks anyway mate !
