torque settings for big ends?
Post 399520 by danny-R on 2011-07-29 18:26:48
Could anybody please tell me what the torque settings for big ends. Also anybody used or can you even get acl race bearings from anywhere? I've been advised to just replace the big ends rather than changing bottom end that way I keep the uprated rods in there and its. afew hours work instead of a couple of days. any help much appreciated cheers
Post 399762 by leet5r on 2011-07-30 10:58:49
make sure they arnt sored m8 other wise there wont last long
Post 399771 by danny-R on 2011-07-30 11:45:36
[quote=leet5r;399762]make sure they arnt sored m8 other wise there wont last long[/quote] scored? Can the big ends be changed by removing the sump mate? Ive ordered a new set from volvo should be here monday, £30 each
Post 399775 by Tomcat on 2011-07-30 11:59:37
Sure you can replace the little ends with just the sump off but the big ends..??, wouldn't that be a crank out job?.
Post 399776 by leet5r on 2011-07-30 12:00:01
yeah m8 , with the big end shell fail the rod and crank might be damaged (ie scored) slight marks on both crank and rod , if the crank is scored you will need a grind and a set of over sized shells
Post 399777 by leet5r on 2011-07-30 12:02:56
[quote=Tomcat;399775]Sure you can replace the little ends with just the sump off but the big ends..??, wouldn't that be a crank out job?.[/quote] ya need to take the crank out for the mains m8, big ends are for the con rods m8 little ends are piston to rods
Post 399778 by danny-R on 2011-07-30 12:04:30
do you know if your mate had it ground last time?
Post 399780 by Tomcat on 2011-07-30 12:09:58
[quote=leet5r;399777]ya need to take the crank out for the mains m8, big ends are for the con rods m8 little ends are piston to rods[/quote] Mmm yeah, that's what I thoght, just got my terminoligy wrong, been a while since I pulled an engine apart and rebuilt it.
