Post 402914 by abdul on 2011-08-10 23:53:43
is castrol 5w 40 fully synthetic good for a t5
[quote=abdul;402914]is castrol 5w 40 fully synthetic good for a t5[/quote] semi synth would be better, fully synth is a bit thin. 10/40 is recomended stuff i think
[quote=t5 stealth;402918]semi synth would be better, fully synth is a bit thin. 10/40 is recomended stuff i think[/quote] yep, go cheap, GSF offers 5L for £12, it takes more than 5L (6.4 I think - check the haynes) so you'll need 2 bottles. I took 3L out of mine, topped it up, ran it for half an hour, drained it and put the rest in... cheap flush :) don't forget to change the filter, I did it when I took the first 3L out.
I would go for 10/40 semi synthetic, I used Halfords own brand on my T5, its good quality oil too and as I change it every 6 months good value too. Its all too easy to get carried away with names on oil bottles too, remember to check the recommended oil for your car, iam going off an 850 T5 which is quite an old engine now and if you go sticking fully synthetic 0w oil in I rekon it would spring a leak somewhere and would be a bit too thin for that engine and its recommended to use 10/40 semi when it was new so that what I use, I have heard of people spending 50 quid on a gallon of top name oil like Mobil 1 etc thinking its gonna improve the performance only for the engine to start rattling and losing oil pressure and leaking, not good for it at all
10-40 for me..
I have only ever used Shell Ultra Helix Fully Synthetic. I believe it is 5W 40. And I change it every 5K miles. Anal or what??!
i use castrol magnatec 10/40.
yeah 10/40 semi in mine
10/40W Magnatec (semi synthetiuc) is a good oil for the Pre ME7 throttle cable cars pre 1999 but 0-30 or 5-30 fully synthetic for newer models
10w40 semi , i use Ac Delco,
10w/40 Magnatec for me as well.. £26 for 4 ltrs in ASDA..
I use Silkoline Pro S 5w30 and change it every 3k although it usually ends up being every 2k because I am paranoid about dirty oil... :cuckoo:
Morris Oil 10/40 semi - 14 a gallon at my work..or 40 for 25l !
[quote=AndysR;412211]I use Silkoline Pro S 5w30 and change it every 3k although it usually ends up being every 2k because I am paranoid about dirty oil... :cuckoo:[/quote] Every 2k? That is paranoid. lol
[quote=LiamT4;412242]Every 2k? That is paranoid. lol[/quote] Tell me about it.... lol
i got told 10/40 semi for both Bonny & BT, saves messing with several different oils lol
