Post 37280 by watteee on 2005-08-10 20:41:24
hi all,fitted my new MAF sensor yesterday and no problems when i started the engine,however ECU fault light on,a wee while later i noticed it was off.
Driving home i put the foot down to overtake,WHOOSH!!! strange i dont remember fitting a dump valve?pulled over and revs the engine,a loud whistling noise van be heard and i traces it to a hose from the intercooler,seems the jubilee clip was rotting,anyway new clip from petrol station and im on my way.
This morning im driving to work and the ECU light is showing its ugly face again and the car is idling up and down from 500-2000rpm,so i pulled over and pulls the MAF plug out to see if that does anything but it gets worse,so i calls the AA again,guy reads the codes,they are as follows:
po102 mass or vol air flow circuit low
po172 system too rich
p1171 fuel volume regulator control circuit open
p1238 " " " " " "
so he clears them and since he has the car has been sweet as a nut but surely something caused the uneven idle to start with ,i might have caused some faults by pulling plugs out,i dont know 2 weeks ive had the car and im losing faith.ADVICE IS REQUIRED!!!!!!!
Post 37296 by Green T5R on 2005-08-10 21:44:12
Just a thought did you disconnect the battery before doing the work?
I've made this mistake before and blown fuses for my trouble.
Regards
Iain
Post 37302 by TangoDeltaSierra3 on 2005-08-10 21:51:14
[QUOTE=watteee]hi all,fitted my new MAF sensor yesterday and no problems when i started the engine,however ECU fault light on,a wee while later i noticed it was off.
p1238 " " " " " "
so he clears them and since he has the car has been sweet as a nut but surely something caused the uneven idle to start with ,i might have caused some faults by pulling plugs out,i dont know 2 weeks ive had the car and im losing faith.ADVICE IS REQUIRED!!!!!!![/QUOTE]Thats why i bite the bullet and pay qualified people to repair mine.
Post 37309 by watteee on 2005-08-10 22:08:09
Thats why i bite the bullet and pay qualified people to repair mine.????? :frown:
are you insinuating that i dont,ive only had a MAF sensor fitted to my car since i got it and i fitted it and a monkey could do that.i suppose its nothing to do with bad luck and a lot seems to be going wrong at the same time.
Post 37317 by t5owner on 2005-08-10 22:29:51
[QUOTE=watteee]Thats why i bite the bullet and pay qualified people to repair mine.????? :frown:
are you insinuating that i dont,ive only had a MAF sensor fitted to my car since i got it and i fitted it and a monkey could do that.i suppose its nothing to do with bad luck and a lot seems to be going wrong at the same time.[/QUOTE]
As green t5r said did you disco the battery b4 u unpluged all sorts :slap:
Post 37321 by TangoDeltaSierra3 on 2005-08-10 22:38:00
are you insinuating that i dont,ive only had a MAF sensor fitted to my car since i got it and i fitted it and a monkey could do that.i suppose its nothing to do with bad luck and a lot seems to be going wrong at the same time.[/QUOTE/ 'I am saying i dont mess with stuff i dont understand.
Post 37323 by watteee on 2005-08-10 22:39:17
i only un plugged the MAF plug and im afraid i didnt disco the battery,what damage did i do by not.
Post 37328 by t5owner on 2005-08-10 22:49:48
[QUOTE=watteee]i only un plugged the MAF plug and im afraid i didnt disco the battery,what damage did i do by not.[/QUOTE]
Thy might of sent a spike back from the battery to the maf and back to the ecu and it gets upset when things happen that it dont like :dunce:
Post 37330 by watteee on 2005-08-10 22:53:57
sorry tds,thought you knew something i didnt,maybe not disconeting the battery has did something,but something caused the ecu light to come on in the first place,no faults at moment as they have been cleared,ans car is ok at mo, will wait to see what transpires
Post 37335 by Green T5R on 2005-08-10 23:08:44
don't think you will have done any damage just freaked out the ECU.
Post 37336 by splatt on 2005-08-10 23:11:35
Try a ECU reset by disconnecting it overnight...just take the negative battery lead off. (know your radio code!!!)
It will take a while to reset once connected but has had some results for me in the past,
