Post 419293 by Pauld on 2011-10-27 16:27:42
My R has developed a clunk she going into drive, or reverse. I sounds as if it is coming from the front off side wheel hub. Any suggestions? Thanks
Engine mount? My old audi did something similar, garage fitted a new mount and it went away.
Sounds like "axle ping". Where the loctite for bolts in the wheel hubs is not so strong. Resolution is to get XC90 axle bolts as these have rubber grommets on them that set a firm seal against the hub and getting rid of the noise. Hope this helps
[quote=burchi;419492]Sounds like "axle ping". Where the loctite for bolts in the wheel hubs is not so strong. Resolution is to get XC90 axle bolts as these have rubber grommets on them that set a firm seal against the hub and getting rid of the noise. Hope this helps[/quote] Have you got a PN for these my dealer is refusing to fit these????
[quote=burchi;419492]Sounds like "axle ping". Where the loctite for bolts in the wheel hubs is not so strong. Resolution is to get XC90 axle bolts as these have rubber grommets on them that set a firm seal against the hub and getting rid of the noise. Hope this helps[/quote] Think this is what happened in my C70, Volvo just re loctited the bolts
[quote=volvokid;419494]Have you got a PN for these my dealer is refusing to fit these????[/quote] part number is 30714142
As a matter of interest for us with AWD, do we need to fit these to the rear as well?
Had a clonk from front o/s when changing gear, thought it was the cv till I found it was the hub bolt, or lack of it! It's too long to just fall out (nowhere for it to go), looks like plod forgot to put it in at some point :eek: All sorted now tho :)
Common fault. They all work loose. Remedy is to replace with XC90 bolts. Martyn i am not sure why your dealer is refusing to fit, its actaully the correct modification to cure axle ping!! Some dealers really are thick! they should read their TNNs once in a while and they might learn something. Make sure you torque the new XC90 bolts to 50Nm not the original 35Nm.
[quote=LeeT5;420443]Common fault. They all work loose. Remedy is to replace with XC90 bolts. Martyn i am not sure why your dealer is refusing to fit, its actaully the correct modification to cure axle ping!! Some dealers really are thick! they should read their TNNs once in a while and they might learn something. Make sure you torque the new XC90 bolts to 50Nm not the original 35Nm.[/quote] TBH I dont think they really knew what i ment. Gonna get it sorted out
If they can't plug it into a laptop or poke it with a stick, they don't wanna know nowerdays. When I had my DIM changed (grrrr) they did a "health check" and found £800 worth of problems but didn't mention my sticky w/g or blocked PCV! tossers.
Please , what do these bolts connect to , is there a diagramme anywhere.
[quote=pwcov;422100]Please , what do these bolts connect to , is there a diagramme anywhere.[/quote]
You mean the hub bolt?
Bang in the middle of the hub (12mm head - I think) about 90mm long. It pulls the C/V into the hub and has a nasty habit of working loose.
Thanks for that Martin. Note from the service history from last owner that these where checked and greased? Think XC90 bolts will be the next thing on my list. Pete W.
TBH, I don't have XC bolts, but I do have the wheels off quite a bit (big 10 and all that) so I torque them up alot. I can see how they'd work loose and how XC bolts would help.
[quote=SomeBloke;420151]As a matter of interest for us with AWD, do we need to fit these to the rear as well?[/quote] No, front wheels only. Pop out the centre cap on the wheel and undo the existing bolt (make sure the female thread is clean) and replace with the XC90 bolt, about as simple as you can get. Takes all of 10 minutes each side.
hi there when i was working with auto gearboxes there was a few reasons, one being the mounts, next being the clutches inside the gearbox are worn, even could go down to being the torque converter, maybe try changing your gearbox fluid (ATF) see if that helps :)
Hub bolts frist and the correct repair is to use XC90 ones as mentioned. Mine where done under warrenty at volvo and they put the XC90s in. Then look at the AFT fluid, I just had mine flushed and replaced.. cost £75.60 in fluid and £25 labour. You need 4 litres of fluid ( 2 to flush and 2 to replace) the gear change is much smoother. After that try the software up-dates for the gear box. After that... well just accept its part of the car cos anything else will be very expensive.
Have you sorted the Clunk noise yet?? Assume your car is an auto? If it's a clunk or clonk noise then it won't be the Hub bolt nor axle ping. It's more lightly to be engine mounting related due to the engine rocking lightly backwards or forwards when you select gear. Check your 'lower transmission mount'. They are sh i te!! The small bush can be ripped out with your teeth so they don't last 5 minutes. It will look ok on the car so you will need to remove the entire bushing. It's very easy to do. Just undo the rear two bolts (14mm i think). see what happens. If the bush falls and swings like a banana then the bush is shagged. Replace with powerflex. Only replace the small bush otherwise your gearchanges will become extremely harsh and not nice to drive in stop start traffic. Takes about 2 minutes to remove with simple tools.
I have replaced the hub bolts and the clunk is significantly reduced. I suspect the bush needs doing also. Thanks for all the advise.
If you suspect the bushes, this might help... http://www.vpcuk.org/forums/showthread.php?t=38699 It may also be worth re-tightening the hub bolts.:)
Torqued them again this morning
Hmm, give the bushes a good levering with a bar and see how easily they move. Maybe check the C/V joints again. You want to go well over the recommended torue settings for the hub bolts too.
[quote=martinrpeachey;425657]Hmm, give the bushes a good levering with a bar and see how easily they move. Maybe check the C/V joints again. You want to go well over the recommended torue settings for the hub bolts too.[/quote] Oh no you don't! If you strip the threads then you'll be buying a new CV outer at £70. The XC90 bolts should only be torqued to max 50Nm. Ensure you use a slight amount of thread lock as this will act a lube for the bolt when tightening and prevent it coming out once fitted.
[quote=Pauld;425651]Torqued them again this morning[/quote] 50Nm. :B_thumb:
Hub bolts are stretch bolts, you can keep torquing them up but they will eventually go ping which isn't good.
I had this problem with my 2004 S60. XC90 drive shaft bolts, poly upper large/upper small, poly lower large/lower small bushings solved the issue. Your upper and lower engine/gbox mounts won't always 'look' worn by the way, but they are often haggered more than you may think.
Agreed, several of my suspension and torque mount bushes were dhoy. Looked ok but when I gave them a wiggle, they were loose as a tramp's trousers!
Question guys - I didn't realise the driveshaft bolts were 'stretch' bolts and obviously, once used and then removed, should not be used again. Now, by looking at them, it seems to me the only difference between the normal S60 bolt and the XC90 bolt is JUST the rubber insert/collar/washer/bung? When I changed my ball joints, I received brand new driveshaft bolts and didn't use them due to having fitted the XC90 bolts. Could I use the XC90 rubber collar on an otherwise S60 bolt? Surely the bolt is physically the same? Can't buy another set of XC90 bolts they cost approx £15 EACH! Which torque setting would I use? 50nm or 35nm? Thanks
If the thread pitch and length of bolt are the same then yes of course you can use them. With the XC90 rubber washers they MUST be torqued to 50Nm, else they will come loose.
[quote=LeeT5;438383]If the thread pitch and length of bolt are the same then yes of course you can use them. With the XC90 rubber washers they MUST be torqued to 50Nm, else they will come loose.[/quote] I'm fairly certain the thread/pitch/length are all the same, but i'll check tomorrow. I'll re-fit at 50nm with a touch of thread lock.
