Post 420213 by BlackC70 on 2011-10-30 14:06:00
Hey all, just a quick question - I've noticed the 3rd brake light on my C70 has expired with the associate brake warning light on the dash. The others are working, but I need to get it sorted asap.
My queries are:
1: Is it an LED strip, and as such a Volvo part, or is it just a rack of bulbs and therefore something easier to replace (I think it's LED, personally)
2: Is there any quick and easy way to replace it, or (as I have a horrible feeling) do I have to remove the back seats and the rear parcel shelf to get to it?
I've had a prod around in the boot but can't see any way of getting it out from below. Does anyone have any information on this?
Cheers!
Post 420214 by BlackC70 on 2011-10-30 14:06:30
Also, could it be something as daft as a fuse, or is that wishful thinking?
Post 420215 by LiamT4 on 2011-10-30 14:08:54
If there is a fuse for the high level brake light, i'd try that first as LED's should have a very long life span.
Post 420217 by BlackC70 on 2011-10-30 14:14:39
I went through the fuse board listing on the fuse cover but there was nothing specific to 3rd brake light. I guess I could test all the fuses if it came to it.
The fact the bulb fail warning light is on when you press the brakes is a bit of a worry though - I honestly think the unit is sitting on a cloud playing a harp.
Post 421336 by SteveRuss on 2011-11-03 07:23:39
[quote=BlackC70;420217]I went through the fuse board listing on the fuse cover but there was nothing specific to 3rd brake light. I guess I could test all the fuses if it came to it.
The fact the bulb fail warning light is on when you press the brakes is a bit of a worry though - I honestly think the unit is sitting on a cloud playing a harp.[/quote]
Get yourself a continuity meter (or borrow a multimeter from someone) and check through all your fuses. Takes a few minutes and then at least you will have taken them out of the equation. It's the most likely cause after all however, the brake lights may all be linked through one fuse. I don't honestly know..
Although LED's have a long shelf life, the electronics associated with them are the same as for any other circuit. Something may have failed in the actual box on the rear window so it's worth a dig around in there.
If you're really lost, then take it to an auto electrical garage as they'll have the schematics and general knowhow.. Normal garages are often useless when it comes to electrical issues. That's my general experience anyway..
Post 441191 by BlackC70 on 2011-12-29 02:53:01
Just a quick update to this - it seems to have rectified itself and all is working fine.
For reference, you need to remove the back seats and parcel shelf to get to the module and associated wiring. Luckily it didn't come to that!
