no boost
Post 420806 by adam280 on 2011-11-01 17:42:11
hi all. can anyone help i have no boost , ive changed the bcs and maf sensor. no engine light on. cant see any splits in pipes it revs and idles ok just so slow. no smoke either, would it smoke if the turbo was knackered? cheers
Post 420817 by bigrotch on 2011-11-01 18:15:00
Have got a mbc, is it plumed in correctly ie swap vac pipes round
Post 420825 by adam280 on 2011-11-01 18:48:42
no mbc, completely standard apart from exhaust. i was driving along all fine and the next time i accelerated it was dead, it struggles to keep up with a transit.
Post 420826 by AndysR on 2011-11-01 18:49:51
What sort of Volvo do you have?
Post 420909 by adam280 on 2011-11-01 21:08:18
sorry forgot to say. its a 1997 v70r
Post 420944 by merc85 on 2011-11-01 21:55:17
Sounds like the bcs is knackered, if you take the vac line off the actuator she should "boost" BUT NEVER DO THIS WITHOUT A BOOST GAUGE AS SHE CAN/WILL BLOW if you dont let off the gas! if she boosts with the vac line off it will prove the bcs is knackered. either fit a mbc or a new BCS valve. If she still doesnt boost it could be a Duff actuator, or a torn recirc valve.
Post 420946 by M-R-P on 2011-11-01 21:58:26
or a sticky waste gate, if it sticks in the open position, it feels fine till you go to accelerate then it goes dull.
Post 421000 by Dangerous Dave on 2011-11-01 23:54:35
Perhaps the actuator arm has come off the pin on the wastegate? Was it a sudden loss of boost?
Post 421013 by MoleT-5R on 2011-11-02 02:22:39
I had no boost on my t5-r, checked everything and in the end it turned out the cat had collapsed, removed the cat and the boost returned immediately. Quick test is to drop the exhaust off the turbo and see if goes any better hope this is of help..
Post 421014 by Joolz_850R on 2011-11-02 06:56:07
[quote=moleadrian;421013]I had no boost on my t5-r, checked everything and in the end it turned out the cat had collapsed, removed the cat and the boost returned immediately. Quick test is to drop the exhaust off the turbo and see if goes any better hope this is of help..[/quote] Ill second that. Car drove lovely until I hit the rolling road and found I had 130HP!!! Took a while but dropped the cat off and it was mullered. Need to make sure you have no misfire also.
Post 421097 by adam280 on 2011-11-02 17:04:01
it wasnt sudden, i was on a 15 mile journey all ok for the first 10 just plodding along then went to floor it and it was gutless. ive double checked the pipes no splits that i can see or feel. i can slightly move the actuator rod backwards and fowards, should this be solid? i have already changed the bcs. thanks adam
Post 421190 by Dangerous Dave on 2011-11-02 19:47:17
The actuator rod should move a little along its length and it should take some effort as it is spring loaded, but the rod shouldn't move side to side. When I say it takes some effort, if try to move the rod on my turbo I can only move it about about 5mm just using my finger and thumb.
Post 421387 by adam280 on 2011-11-03 17:11:34
the rod on the actuator is quite loose it moves side to side and up and down. i can move it about 7~8 mm. i cant see all the actuator because of the heat shield. will a normal t5 one fit the v70r? are they hard to fit
Post 421463 by Dangerous Dave on 2011-11-03 21:35:53
Thats not right then, it should be fixed tight. You need to get the heatshield off to get a better look at the other end of the actuator rod, its only a few bolts and it slides out the way (no need to take it out from behind the engine). Its just a bit of a pain to get to one of the bolts down the water pump end of the engine. It could possibly be as simple as the end has come off the actuator arm and just needs putting back on with a new locking pin.
Post 421468 by adam280 on 2011-11-03 21:44:16
hope so mate will check 2moro
Post 431883 by adam280 on 2011-12-02 16:06:51
Fitted my new actuator today and the car is just the same,just glad I didn't buy a new one. gonna have to check the cat.
Post 431885 by T5frankie on 2011-12-02 16:12:10
[quote=adam280;431883]Fitted my new actuator today and the car is just the same,just glad I didn't buy a new one. gonna have to check the cat.[/quote] with a knackered cat you will have some boost as joolz did but not enough, yours has no boost at all
Post 431893 by M-R-P on 2011-12-02 16:56:14
starting to sound like a cracked turbo :eek:
Post 431900 by adam280 on 2011-12-02 17:12:17
Oh great, what's the best way to tell if the turbos knackered?
Post 431902 by adam280 on 2011-12-02 17:16:23
I forgot we put your gauge on it. It ain't looking good is it,could the recirc valve be leaking?[quote=t5frankie;431885]with a knackered cat you will have some boost as joolz did but not enough, yours has no boost at all[/quote]
Post 431905 by M-R-P on 2011-12-02 17:19:59
Take the turbo off and have a good look inside the exhaust housing. If it's cracked, You'll see. Try the recirc first tho, it's easier to do. I have a working one (off a 16t) if you need it.
Post 431907 by mitchyboy01 on 2011-12-02 17:28:04
Is it running like a tractor? Bottom boost hose come of intercooler??
Post 431908 by mitchyboy01 on 2011-12-02 17:29:24
Ignore that, I re read your original post and saw it's running ok doh
Post 431910 by T5frankie on 2011-12-02 17:32:14
[quote=adam280;431902]I forgot we put your gauge on it. It ain't looking good is it,could the recirc valve be leaking?[/quote] we didnt hear any air leaks anywhere
Post 431911 by T5frankie on 2011-12-02 17:32:54
[quote=mitchyboy01;431907]Is it running like a tractor? Bottom boost hose come of intercooler??[/quote] his car runs quiet and smooth and drives normal just with no boost
Post 431912 by M-R-P on 2011-12-02 17:33:54
What sort of mileage/abuse are we looking at? could well be recirc.
Post 431913 by T5frankie on 2011-12-02 17:35:39
and we tried my mbc on and still nothing
Post 431921 by adam280 on 2011-12-02 18:02:09
As frankie said runs ok just so slow, might try a blanking plate I've got a dump valve just gotta get a fitting kit
Post 540617 by Rudeyboy18 on 2012-10-07 21:44:01
Did you get a resolution of this fault Adam280?
