ATF Changing - Advice Pls
Post 38142 by swordy21 on 2005-08-16 09:46:04
I need to change my Transmission Fluid. The car has done about 20K since I've had it and the fluid is a little browner than I would like and is starting to smell a bit. I have also noticed it is a bit harsher on changes and seems to short shift 2nd to 3rd. No other issues really and more of a precaution for longevity. So Questions:- How much ATF should I buy? What diameter clear plastic tubing do I need to fit over the (is it?) return hose for flushing. Any specific spanners/tools needed? Obviously when started must be finished, so I don't want to get 1/2 way through and find I'm missing something. Cheers guys
Post 38230 by k690bpp on 2005-08-16 17:35:08
check this: http://www.volvospeed.com/Repair/Transflush.php
Post 38378 by Wobbly Dave on 2005-08-17 12:13:50
If you want I can come down and see you and show you how to do it. You need about 15 litres to do a proper flush. I have done about 5 full changes. I can show you the new C70 and the 19T?
Post 38380 by Wobbly Dave on 2005-08-17 12:16:13
I can also bring you some shims to stop yer brakes from squeaking.
Post 38431 by k690bpp on 2005-08-17 16:45:59
are you still selling atf coolers dave???
Post 38436 by Wobbly Dave on 2005-08-17 16:57:48
Yeah mate - I developed the system so I can still make them up.
Post 38439 by k690bpp on 2005-08-17 17:05:47
how much and do you come and fit it or do i come see you.
Post 38530 by Wobbly Dave on 2005-08-17 22:45:37
Location is entirely upto you. Personally I prefer my place but that is just coz it is easier. I did Andrew Cardwells install in Cambs - so I am flexible. Price is as stated on this thread (you can see pics of his install) http://www.volvot5.co.uk/forums/showthread.php?t=899 I am using top quality parts which are not cheap to buy. Install takes about 1 - 2 hrs. If you want me to come to you then I can but I will need petrol expenses.
Post 38632 by swordy21 on 2005-08-18 12:16:45
[QUOTE=Wobbly Dave]If you want I can come down and see you and show you how to do it. You need about 15 litres to do a proper flush. I have done about 5 full changes. I can show you the new C70 and the 19T?[/QUOTE] Cheers for the offer Dave, may very well take you up on it, however need to work out when to do this, only got 1 weekend left before we go on hols, ie this one, and need to use this to get the rest of our camping tackle sorted. May be easier timewise, if I could pop up to you on a weekday if you're not working, I can always justify a trip out of the office. I'll have a think and maybe give you a ring. Would deffo like to see the new car & turbo......I'll bring my steel pants. Ref brakes squeeking - I must have the only T5 now with no shims and no squeeks.....since I changed my rotors and pads, no squeeks. I did find the culprit though, was the front OS calliper, piston was sticky, so a bit of fiddling and that sorted that. If I get more time, I may do a complete refurb on the calliper, and get the boot back in place properly. I'll let you know on the ATF thing..... Cheers
Post 38634 by Wobbly Dave on 2005-08-18 12:23:16
I have nothing planned for this weekend - so I would be more than happy to come on down. I can do the change and you got and sort out yer bits and pieces?
