Post 432555 by foammanmark on 2011-12-04 17:55:16
I have a bulb out below the speedo which is one of those things that I just have to sort. Please could someone advise me on the basics of this job. I can see 2 screws above the clocks, but I thought I would ask before I start.
Thanks in anticipation!
Post 432561 by daza-b on 2011-12-04 18:05:10
[quote=foammanmark;432555]I have a bulb out below the speedo which is one of those things that I just have to sort. Please could someone advise me on the basics of this job. I can see 2 screws above the clocks, but I thought I would ask before I start.
Thanks in anticipation![/quote]
if you can wait a short while i can put a step by step guide/thread on here for you :)
Post 432562 by foammanmark on 2011-12-04 18:08:09
[quote=dazab;432561]if you can wait a short while i can put a step by step guide/thread on here for you :)[/quote]
Thanks! I won't be looking at this now until next weekend at the earliest, and I look forward to the guide!
I would normally just get stuck into a job like this, but with now being on the forum, I'm becoming lazier by asking before I start!
Post 432564 by The Flying Moose on 2011-12-04 18:12:02
Its not a massive job, there are around 12 T20 or T25 Torx screws to remove.
You firstly need to remove the air vents as there is a screw behind each vent, you also need to remove the dash speakers and the side of dash air vents.
After this it just slides off and gives you access to the clocks.
Post 432576 by daza-b on 2011-12-04 18:35:14
moose has already told you, ill still do it with pics lol
