Boost Gauge Help
Post 434044 by MattM on 2011-12-08 17:02:32
Thought I would start a new thread as I'm going off track in the remap issues thread. So I've decided I want to fit a mechanical boost gauge. I think this one will do the job nicely - http://www.ebay.co.uk/itm/PROSPORT-SMOKED-SUPER-WHITE-BOOST-GAUGE-KIT-BAR-/110786076787?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19cb5d6073 Going to mount it in a pod like this - http://www.partsforvolvosonline.com/product_info.php?cPath=28_225&products_id=6760 The area where I want to put it creates a challenge - sat on top of the dashboard next to the a-pillar. I think I can get the tube into the cabin OK, but I want it to be where I have circled. I've had a look and the gaps between the window/A-Pillar/Dash are very small, and would likely squash the tubing. Does anyone know a way to route it up to the point I want? Perhaps a way through the fuse area? Image
Post 434054 by M-R-P on 2011-12-08 17:22:29
Not without drilling the dash. Airvents are a popular place to put it. Storm Troll had a nice example.
Post 434058 by MattM on 2011-12-08 17:24:30
The other option which looks good is the door mount, can be tricky to install as I'd need to remove door card and pipe through the door. http://carbonfiberwerks.stimuluscreations.com/s60.htm
Post 434061 by bigrotch on 2011-12-08 17:26:17
THATS where ive got mine in my 850, i got the cables and vac pipe down the back of dash by unscrewing side vent and threading it through then wired it up to the light swith and put t piece in the vac line under the steering colum
Post 434070 by MattM on 2011-12-08 17:34:01
Got any pics?
Post 434073 by bigrotch on 2011-12-08 17:36:51
back in a mo just take one for ya
Post 434075 by volvo on 2011-12-08 17:37:12
lol...take one for me too!
Post 434076 by MattM on 2011-12-08 17:37:15
Legend :)
Post 434083 by bigrotch on 2011-12-08 17:51:32
they wires do need to be pushed together to look neater but hay ho hope this helps and i just poped out the light switch and spliced the wires into wires
Post 434086 by volvo on 2011-12-08 17:52:45
Gav...i dont think my bro is in this weekend you know......
Post 434087 by bigrotch on 2011-12-08 17:53:40
no probs just let us know when fella
Post 434088 by volvo on 2011-12-08 17:55:36
will do! Thanks
Post 434089 by MattM on 2011-12-08 17:56:09
I had a look at that gap and I can't see how I'd fit a tube down there without it being squashed, at least in my car. That's where I want it though :) Maybe there is a way of feeding it up from the back of the dash where it meets the window.
Post 434092 by bigrotch on 2011-12-08 18:04:21
on the 850 there is a vent on the side of the dash open the door pop out the plug.undo t25 torx pull out vent undo other torx then the dash corner pulls away abit. take the footwell cover off 3 x t25torx shine a bright light up there and poke the vac pipe down the gap. u will spot it with the light the grab it and gentle pull it down, pop out the light switch shine ya light through the switch hole, i taped the 3 wires together to help threading. once u spot them guide them through until u can pull them through the swith hole. my wireing will be different to yrs i had 3 wires for my gauge as its got different coulour leds easy to find which is what tho
Post 434110 by MattM on 2011-12-08 18:53:46
Cheers. Looking at this link I think I may go down this route. http://forums.swedespeed.com/showthread.php?129950-IPD-R-Boost-Gauge-with-CF-Werks-Door-Pod-Writeup
Post 434111 by bigrotch on 2011-12-08 19:03:19
bit more fidly than nyne but looks the nuts tho mate post some oics when ya doit
