Tinted windows..
Post 434775 by willi on 2011-12-10 18:30:01
Hi Guys.. My V70r has got rear black tints which does look quite good. Only problem is on the inside of the tints is like a white powdery film.. Its as though the tints are going mouldy.. You can scrape it off with a finger nail which obviously takes yonks.. Has anyone ever comes across this before, and if so how did it get there and what is the best wqy of removing it please.:worried:
Post 434859 by foammanmark on 2011-12-10 19:55:34
[quote=willi;434775]Hi Guys.. My V70r has got rear black tints which does look quite good. Only problem is on the inside of the tints is like a white powdery film.. Its as though the tints are going mouldy.. You can scrape it off with a finger nail which obviously takes yonks.. Has anyone ever comes across this before, and if so how did it get there and what is the best wqy of removing it please.:worried:[/quote] Dazab- can you help with this?
Post 434895 by daza-b on 2011-12-10 20:19:54
i dont know why i did not see this before... if you want to remove them its pretty simple, you will need a flat blade, like a scraper, and you will need some tar and glue remover, can get that from your local motor factors, if your anywhere near me i can remove all for £20 ;)
Post 434931 by foammanmark on 2011-12-10 20:49:09
[quote=dazab;434895]i dont know why i did not see this before... if you want to remove them its pretty simple, you will need a flat blade, like a scraper, and you will need some tar and glue remover, can get that from your local motor factors, if your anywhere near me i can remove all for £20 ;)[/quote] Mate, I'm like your second set of eyes on here! The enquiry yesterday and now this! We're a team!
Post 434932 by T5frankie on 2011-12-10 20:51:11
hairdryer mate and a scraper
Post 434956 by willi on 2011-12-10 21:11:41
[quote=dazab;434895]i dont know why i did not see this before... if you want to remove them its pretty simple, you will need a flat blade, like a scraper, and you will need some tar and glue remover, can get that from your local motor factors, if your anywhere near me i can remove all for £20 ;)[/quote] I dont want to remove the tint, i want to get rid of the powdery substance or what ever it is off of the tint..lol
Post 434958 by daza-b on 2011-12-10 21:13:03
[quote=willi;434956]I dont want to remove the tint, i want to get rid of the powdery substance or what ever it is off of the tint..lol[/quote] ahhhh is it on the outside of the tint (in the car) or is it between the tint and the window?
Post 434978 by willi on 2011-12-10 21:34:22
Its on the outside of the tint.. You can remove with your fingernail if carefull.. Wot is it do you know plz??
Post 434984 by daza-b on 2011-12-10 21:36:26
[quote=willi;434978]Its on the outside of the tint.. You can remove with your fingernail if carefull.. Wot is it do you know plz??[/quote] not sure buddy never seen or heard it before, try using some luke warm soapy water and see if that removes it..
Post 435006 by willi on 2011-12-10 21:47:56
[quote=dazab;434984]not sure buddy never seen or heard it before, try using some luke warm soapy water and see if that removes it..[/quote] Ok thanx.. I will give it a go. Its in the garage now so i will try now..
Post 435009 by daza-b on 2011-12-10 21:49:37
[quote=willi;435006]Ok thanx.. I will give it a go. Its in the garage now so i will try now..[/quote] ok let me know :)
Post 435019 by willi on 2011-12-10 22:01:09
Just tried warm soapy water, it certainly comes off easier.. Perhaps a credit card edge might be easier than the finger nail.. Thanks
Post 435023 by daza-b on 2011-12-10 22:03:16
[quote=willi;435019]Just tried warm soapy water, it certainly comes off easier.. Perhaps a credit card edge might be easier than the finger nail.. Thanks[/quote] yes its worth a try, but be very careful that you dont scratch the tint, as it will make it look a mess, i would use valeting products but that just me being a valeter, maybe try some tar and glue remover too, not to expensive and always comes in handy
