18t Angle 16t Angle Same dia?? 3"
Post 434790 by merc85 on 2011-12-10 18:47:36
Hi There, Is the 18t angled Turbo Exhaust housing which is 3" internal dai, The Same as a 16t angled Exhaust housing? Trying to find a front pipe/cat to suite, All the exhaust housings are interchangible but it's the front pipe which differ's. Here's a pic of a 15g straight housing, and the 18t housing [ATTACH]12015[/ATTACH]
Post 434802 by claymore on 2011-12-10 18:59:44
I'v got a 16t angle flange on mine, and it's a 3" outlet
Post 434817 by merc85 on 2011-12-10 19:10:28
[quote=claymore;434802]I'v got a 16t angle flange on mine, and it's a 3" outlet[/quote] What Volvo was the 16t Angled housing from buddy?
Post 434820 by claymore on 2011-12-10 19:13:02
[quote=merc85;434817]What Volvo was the 16t Angled housing from buddy?[/quote] I seem to think it was off an 2004 t5 of some sort
Post 434826 by merc85 on 2011-12-10 19:20:24
My thinking is to get a Cat/front pipe from a 2004 or at least a me7 v70 running a angled 16t and mod it to fit the 18t on my 850. Does this sound pluresible ?
Post 434828 by claymore on 2011-12-10 19:22:26
[quote=merc85;434826]My thinking is to get a Cat/front pipe from a 2004 or at least a me7 v70 running a angled 16t and mod it to fit the 18t on my 850. Does this sound pluresible ?[/quote] Sounds like a good plan to me
Post 434939 by T5frankie on 2011-12-10 20:57:12
all angled are 3" and straight are 2.5" like mine
Post 434941 by bigrotch on 2011-12-10 20:59:02
so what u got on the 19t frankie 2.5 or 3, would it hurt having a 2.5 houseing insted of a 3
Post 434946 by T5frankie on 2011-12-10 21:02:12
[quote=bigrotch;434941]so what u got on the 19t frankie 2.5 or 3, would it hurt having a 2.5 houseing insted of a 3[/quote] 19t with a 2.5" straight flange, i don't think it makes any difference with our cars mate my car still made 300bhp at 17psi
Post 435027 by Alan M on 2011-12-10 22:09:26
The angled housing is the better item to have and they are less prone to cracking. The angled housing is a better shape and the outlet is in a better position for the exhaust gas to exit the turbine. You will be best to get an angled housing from a 2001 on 70 or 60 T5. Remember though that the T5 switched to using the K24 from 2005. The angled housings on the pre 2000/2001 phase 2 70 series model 70 series ME7 cars have a smaller inlet into the turbine housing from the manifold flange side as they use the same manifold with slight alterations to it, as the motronic T5 manifolds. The later models are much more open as they use the Japanifold ME7 manifold that many people use.
Post 435031 by T5frankie on 2011-12-10 22:11:51
i think all the "t" turbos were the same size exhaust housing (straight flange)
Post 435056 by merc85 on 2011-12-10 22:31:37
[quote=Alan M;435027]The angled housing is the better item to have and they are less prone to cracking. The angled housing is a better shape and the outlet is in a better position for the exhaust gas to exit the turbine. You will be best to get an angled housing from a 2001 on 70 or 60 T5. Remember though that the T5 switched to using the K24 from 2005. The angled housings on the pre 2000/2001 phase 2 70 series model 70 series ME7 cars have a smaller inlet into the turbine housing from the manifold flange side as they use the same manifold with slight alterations to it, as the motronic T5 manifolds. The later models are much more open as they use the Japanifold ME7 manifold that many people use.[/quote] With info like that who can argue
Post 435151 by Alan M on 2011-12-11 01:17:09
The 16t came in pre ME7 Straight flange, Early ME7 angled and later ME7 angled. The 18t came in Straight, Early ME7 angled, the 19t came in late ME7 angled. The CHRA on all the models can vary slightly with water jacket holes being in different places due to the application intended.
Post 435158 by T5frankie on 2011-12-11 08:33:51
[quote=Alan M;435151]The 16t came in pre ME7 Straight flange, Early ME7 angled and later ME7 angled. The 18t came in Straight, Early ME7 angled, the 19t came in late ME7 angled. The CHRA on all the models can vary slightly with water jacket holes being in different places due to the application intended.[/quote] my 19t came with a straight flange lol
Post 435179 by p fandango on 2011-12-11 09:50:11
[quote=t5frankie;435158]my 19t came with a straight flange lol[/quote] then its been changed lol. 19t only came on the 2000- ME7 V70R AWD with the B5244T2 engine
Post 435181 by T5frankie on 2011-12-11 09:54:39
[quote=p fandango;435179]then its been changed lol. 19t only came on the 2000- ME7 V70R AWD with the B5244T2 engine[/quote] i know thats why i put a little lol on the end mate lol
