Post 441788 by mick850R on 2011-12-30 20:37:52
Hi guys I've suddenly had a bulb or 2 go on the dash clocks where the time and consumption of fuel is displayed, now do I have to remove the binnacle fully or can I reach up behind th dash to change? Gonna look tomorrow but any help tonight would be great. Cheers
Mick
Post 441800 by nottsgreent5 on 2011-12-30 20:51:31
easiest way is to take top off dash think its 8 torxs in top of the vents and 1 each end under the door rubber then theres two clips hold the clocks in dissconect the plugs and pull clocks up and out if thats any help lol
Post 441806 by foammanmark on 2011-12-30 20:59:52
[quote=nottsgreent5;441800]easiest way is to take top off dash think its 8 torxs in top of the vents and 1 each end under the door rubber then theres two clips hold the clocks in dissconect the plugs and pull clocks up and out if thats any help lol[/quote]
Is it the same procedure as the p1 V70 please, as I have a step by step guide that Dazab did for me?
Post 441809 by foammanmark on 2011-12-30 21:02:22
[quote=mick850R;441788]Hi guys I've suddenly had a bulb or 2 go on the dash clocks where the time and consumption of fuel is displayed, now do I have to remove the binnacle fully or can I reach up behind th dash to change? Gonna look tomorrow but any help tonight would be great. Cheers
Mick[/quote]
http://www.vpcuk.org/forums/showthread.php?t=39274
This is a guide that Dazab did for the p1 V70. I don't know if your's would be similar or not?
Post 441811 by nottsgreent5 on 2011-12-30 21:07:48
pretty sure there near enough the same
