S60 2.4T 200bhp AFR befor and after remap
Post 442712 by fassi1 on 2012-01-01 20:51:24
Hello everyone Planning to remap my 2.4T what could give me about 30bhp extra. Before doing it want to make sure that engine is running fine. What i've noticed is that in hard acceleration AFR stays in between 14.2-14.5, lambda 0.98-0.92. I have factory fited wideband O2 sensor and ECU stays in CL all the way up. Is that correct AFR in hard acceleration for this engine, which is B5244T3. I bought new MAF, there is no faults, fuel trims seems to be ok, O2 sensor switches (avg 1 at idle, AFR 14.6-14.7) Planning to visit HLM, but before that i want to make sure that there is everything fine with the engine. Many thanks.
Post 442715 by M-R-P on 2012-01-01 20:55:51
Not sure about your readings but your engine has major potential depending how deep your pockets are ;)
Post 442721 by fassi1 on 2012-01-01 21:09:00
To be honest i spoke to 2 Volvo specialists and no one gave me satisfying answer, looked like they have no idea whats correct AFR for this engine. If thats correct AFR its possible to achieve quite a lot by remapping the ECU which means to get the engine running rich lets say AFR about 11. As far as i know max i can get by remapping is about 30-35bhp and 60-70NM of torque.
Post 442733 by M-R-P on 2012-01-01 21:40:14
Well, from what I've learned here, with a bigger turbo, bigger injectors and then a remap (plus a few other bits and bobs) you'd be looking at a 100hp increase. Like I said, depends on your budget. Hamish at HLM will be able to give you a definitive answer regarding your readings. From what I've read about HLM, they won't just throw a map at it and send you on your way. I'm hoping to head up there myself, funds permitting.
Post 442741 by fassi1 on 2012-01-01 21:56:07
My S60 is FWD so im not sure if its worth to put so much power on just 2 wheels. i reckon 4WD would make sens. Definitely will give this guys call, very interested what they gonna say about AFR.
Post 442747 by t5_monkey on 2012-01-01 22:07:46
It's daft to get a 2.4 T and tune the arse outta that. You'd be better off just going with a remap and enjoying 230bhp of lag free surge :) or get a T5..... you'll be ok up to about 350bhp if you get a quaife... any more and it could get interesting... depends if you like getting a workout when you drive or not :)
Post 442757 by smithy on 2012-01-01 22:20:46
[quote=fassi1;442712]Hello everyone Planning to remap my 2.4T what could give me about 30bhp extra. Before doing it want to make sure that engine is running fine. What i've noticed is that in hard acceleration AFR stays in between 14.2-14.5, lambda 0.98-0.92. I have factory fited wideband O2 sensor and ECU stays in CL all the way up. Is that correct AFR in hard acceleration for this engine, which is B5244T3. I bought new MAF, there is no faults, fuel trims seems to be ok, O2 sensor switches (avg 1 at idle, AFR 14.6-14.7) Planning to visit HLM, but before that i want to make sure that there is everything fine with the engine. Many thanks.[/quote] yours is a low pressure turbo i would say but them afrs seem to be on the lean side to me but when you go to hamish at hlm he will sort all that out for you and the remap will sort any other issues out with the car.the 30 bhp extra is very conservative they normally produce more.and because you are running a small turbo the will be no lag and will go like stink mate.get the map done you wont be disapointed.also hamish always does a run on the rollers before and after so that will show the genuine afrs the car is producing before and after the remap.
Post 442760 by M-R-P on 2012-01-01 22:25:57
Wouldn't a better turbo and map turn it into a T5 any way? The older T5s are 250bhp with a smaller cc and a dull map (i know) and an S60 won't be as lairy as a S40 with with the same power due to the extra weight and wider stantz. I recon, after the remap, the bug may well bite ;). Above all, enjoy her mate, you gotta nice little chariot there.
Post 442771 by smithy on 2012-01-01 22:34:19
[quote=martinrpeachey;442760]Wouldn't a better turbo and map turn it into a T5 any way? The older T5s are 250bhp with a smaller cc and a dull map (i know) and an S60 won't be as lairy as a S40 with with the same power due to the extra weight and wider stantz. I recon, after the remap, the bug may well bite ;). Above all, enjoy her mate, you gotta nice little chariot there.[/quote] they are not the same engine mate but they do map well and pull like a steam train due to the small turbo.i had a v70 2.5lpt and standard the car would do a quater in 16.2 just after a remap it did 15.2 standard power was 193bhp and remapped power was 240bhp but more alot more torque than a t5.it was a very quick car mate
Post 442782 by fassi1 on 2012-01-01 22:39:56
I must say this engine loves low revs, so much torgue from standard. Remap should make it more fun.
Post 442793 by smithy on 2012-01-01 22:47:54
yes yes yes lol
Post 442796 by M-R-P on 2012-01-01 22:53:12
[quote=smithy;442771]they are not the same engine mate but they do map well and pull like a steam train due to the small turbo.i had a v70 2.5lpt and standard the car would do a quater in 16.2 just after a remap it did 15.2 standard power was 193bhp and remapped power was 240bhp but more alot more torque than a t5.it was a very quick car mate[/quote] I meant the 2.4 block itself, being very strong (I'm presuming the block is the same?), given the right tuning they can chuck out serious horses depending on the size of bank balance and size of yer balls lol. Sertainly not trying to say that a remap alone isn't enough, more singing the praises of the Volvo 5 pot ;)
Post 442802 by smithy on 2012-01-01 23:04:32
i agree with you mate but i think they are different engines mate
Post 442808 by M-R-P on 2012-01-01 23:11:44
I was under the impression the block, head, and various other bits were the same as a t 5. I won't risk arguing about it cos I'm still a newbie and don't wanna get shot down lol.
Post 442809 by smithy on 2012-01-01 23:14:51
[quote=martinrpeachey;442808]I was under the impression the block, head, and various other bits were the same as a t 5. I won't risk arguing about it cos I'm still a newbie and don't wanna get shot down lol.[/quote] to be honest mate i dont know ether and know about the 2.3 t5 and pre me7 engine boxs etc ,all i know is the 2.4t5 engine is the strongest volvo ever built.but still not as strong as a redblock though lol
Post 442812 by M-R-P on 2012-01-01 23:19:34
You and your red block!, not gonna give you any grief about it 'cos It's luurvely! ;)
Post 442819 by smithy on 2012-01-01 23:33:29
[quote=martinrpeachey;442812]You and your red block!, not gonna give you any grief about it 'cos It's luurvely! ;)[/quote] lol
Post 442823 by Dangerous Dave on 2012-01-01 23:44:25
[quote=martinrpeachey;442812]You and your red block!, not gonna give you any grief about it 'cos It's luurvely! ;)[/quote] Even though it is a measly 136bhp.......
Post 442831 by smithy on 2012-01-01 23:52:50
[quote=bomb192uk;442823]Even though it is a measly 136bhp.......[/quote] 137 bhp and will run for a million miles that has been proved so i know ive chose well lol
Post 442834 by Dangerous Dave on 2012-01-01 23:58:29
[quote=smithy;442831]137 bhp and will run for a million miles that has been proved so i know ive chose well lol[/quote] Tell me about it, wish I had a redblock. Just found out my headgasket has gone (3rd time now)
Post 442836 by smithy on 2012-01-02 00:01:57
[quote=bomb192uk;442834]Tell me about it, wish I had a redblock. Just found out my headgasket has gone (3rd time now)[/quote] must be doing something wrong mate never had a headgasket go on a volvo yet
Post 442947 by jardon on 2012-01-02 10:44:09
AFRS around stoich (14.7) or Lambda 1 are common in stock/mild turbo cars - they will run richer if component protection is required. Mapping will include running more boost and this is a useful article on fuelling - fundamental stuff. Not sure how experienced you are with this so forgive me if it's patronising. http://www.volvoclub.org.uk/air-fuel-ratios.shtml
Post 443181 by fassi1 on 2012-01-02 17:51:47
[quote=jardon;442947]AFRS around stoich (14.7) or Lambda 1 are common in stock/mild turbo cars - they will run richer if component protection is required. Mapping will include running more boost and this is a useful article on fuelling - fundamental stuff. Not sure how experienced you are with this so forgive me if it's patronising. http://www.volvoclub.org.uk/air-fuel-ratios.shtml[/quote] Good job mate. This article is the answer to my question. I specialize in LPG installation so there was no problem with understanding this article, very useful. Most of the cars i met run with lambda a lot less than 0.9 (0.8 or even 0.7) so what i've experianced with 2.4T (LPT) whas not what i was expecting. When i tune LPG conversion i always do it to the same lambda or AFR as on the petrol. When i unpluged MAF, AFR droped down to even 10.8 so it was the reason of component protection. You've done a really god job mate, many thanks.
Post 443651 by fassi1 on 2012-01-03 13:33:12
Got the confirmation from HLM Hamish and they run with lambda 0.9-1 and booked in for tuning this saturday. Interested whats gonna look like after tuning???? Cant wait.
Post 443654 by MattM on 2012-01-03 13:47:21
Enjoy mate :) let us know how you get on.
Post 443655 by smithy on 2012-01-03 13:47:39
[quote=fassi1;443651]Got the confirmation from HLM Hamish and they run with lambda 0.9-1 and booked in for tuning this saturday. Interested whats gonna look like after tuning???? Cant wait.[/quote] weldone you wont be disappointed mate say hi from me smithy he knows quite well
Post 443660 by fassi1 on 2012-01-03 14:02:05
Yeah, i will say. Very very interested how is it gonna perform on lpg. At the moment i cant feel any differance between petrol and lpg.
Post 446066 by fassi1 on 2012-01-07 19:10:51
Hi everyone. Some new boost been achieved on my 2.4T and from standard 1.31bar reached max 1.72bar. Running full boost and max 6200rpm on lpg without noticeable power difference. Very satisfied from car performance and HLM service.
Post 446070 by smithy on 2012-01-07 19:16:47
a nice 50 whp there mate and alot more talk but i think the boost levels you are talking about are abit conserative lol
Post 446078 by fassi1 on 2012-01-07 19:26:14
That"s with standard air induction. Maybe could achieve slightly better result with custom cold air induction? What do u reckon?
Post 446087 by T5frankie on 2012-01-07 19:31:46
[quote=fassi1;446066]Hi everyone. Some new boost been achieved on my 2.4T and from standard 1.31bar reached max 1.72bar. Running full boost and max 6200rpm on lpg without noticeable power difference. Very satisfied from car performance and HLM service.[/quote] your car didnt boost at 1.31 mate and wont be 1.72 now maybe 0.31 and 0.72
Post 446090 by smithy on 2012-01-07 19:35:00
[quote=fassi1;446078]That"s with standard air induction. Maybe could achieve slightly better result with custom cold air induction? What do u reckon?[/quote] i recon an exhaust and racecat would be better mate but the cone filters do sound nice though even though a panel performance filter will do fine mate
Post 446092 by fassi1 on 2012-01-07 19:37:28
MAP befor 1.31bar, after 1.72bar Everyone knows what does LPT can do.
Post 446096 by T5frankie on 2012-01-07 19:39:42
[quote=fassi1;446092]MAP befor 1.31bar, after 1.72bar Everyone knows what does LPT can do.[/quote] a low pressure turbo does not boost at 1.31 bar mate thats 19 psi the clue is in the name low pressure a t5 standard is only 0.8 bar which is a high pressure turbo, 1.72 bar = 25 psi
Post 446098 by Al115 on 2012-01-07 19:40:45
Nice result, but suggest you edit your post above to remove a reference to the speed you were doing on a particular public road.
Post 446102 by Pinup_gal on 2012-01-07 19:44:12
Guys can we refrain from posting about speeding on public roads/highways. :)
Post 446106 by T5frankie on 2012-01-07 19:46:15
[quote=Pinup_gal;446102]Guys can we refrain from posting about speeding on public roads/highways. :)[/quote] can we? lol
Post 446111 by Santa on 2012-01-07 19:49:31
[quote=t5frankie;446106]can we? lol[/quote] Yep, you can ;-)
Post 446116 by fassi1 on 2012-01-07 19:51:08
[quote=t5frankie;446096]a low pressure turbo does not boost at 1.31 bar mate thats 19 psi the clue is in the name low pressure a t5 standard is only 0.8 bar which is a high pressure turbo, 1.72 bar = 25 psi[/quote] The max MAP value on NA engines is 1bar so on turbo engines max MAP is >1bar following that im not wrong. I agree that extra boost i got before was 0.31bar and after 0.72.
Post 446118 by T5frankie on 2012-01-07 19:51:26
[quote=Santa;446111]Yep, you can ;-)[/quote] no i did 71 the other day (in a 30 lol) only kidding it was 80 lol
Post 446122 by Dangerous Dave on 2012-01-07 19:52:10
[quote=fassi1;446092]MAP befor 1.31bar, after 1.72bar Everyone knows what does LPT can do.[/quote] On the older LPTs (850 and V70) the standard LPT mapped pressure is about 6psi. The smaller turbo runs out of flow somewhere around 14psi. Not sure what the later cars will run to as I'm not sure what turbo they use
Post 446125 by T5frankie on 2012-01-07 19:53:14
[quote=fassi1;446116]The max MAP value on NA engines is 1bar so on turbo engines max MAP is >1bar following that im not wrong. I agree that extra boost i got before was 0.31bar and after 0.72.[/quote] well done anyway remaps are cool and addictive you'll be going to the petrol station more often now lol
Post 446137 by Santa on 2012-01-07 19:57:53
[quote=t5frankie;446118]no i did 71 the other day (in a 30 lol) only kidding it was 80 lol[/quote] Frankie, please don't start matey......rules are to protect you lot more than me.....unless you already have the points and SP50 for the crime its best not advertising that you did it, I would hate to have to be forced by court order to hand over IP details etc. Edit : suppose 80 in a 30 is an SP30 offence...........let me know when you get done for it :-p
Post 446140 by fassi1 on 2012-01-07 20:00:08
[quote=t5frankie;446125]well done anyway remaps are cool and addictive you'll be going to the petrol station more often now lol[/quote] Yeah probably will have to hi hi. Driving up and down from Luton which in total was about 220miles cost me £33, not bad :)
Post 446145 by T5frankie on 2012-01-07 20:01:48
[quote=Santa;446137]Frankie, please don't start matey......rules are to protect you lot more than me.....unless you already have the points and SP50 for the crime its best not advertising that you did it, I would hate to have to be forced by court order to hand over IP details etc. Edit : suppose 80 in a 30 is an SP30 offence...........let me know when you get done for it :-p[/quote] ive done 80000 miles so far this year and not one speeding offence for this year or any year cos i have never been done for speeding, and as if i'd speed in a 30 zone i have 6 kids mate
Post 446153 by Santa on 2012-01-07 20:05:25
[quote=t5frankie;446145]ive done 80000 miles so far this year and not one speeding offence for this year or any year cos i have never been done for speeding, and as if i'd speed in a 30 zone i have 6 kids mate[/quote] LOL well I'd hope those without kids don't speed outside of schools either. Just respect the fact mate that posting about committing illegal acts isn't going to be tolerated
Post 446158 by LiamT4 on 2012-01-07 20:08:34
Can i ask how the law works regarding this issue? I means if theres no witness/video etc, then how can you be prosecuted for typing a sentence? Wheres the proof, you could be making it up.
Post 446168 by mitchyboy01 on 2012-01-07 20:12:10
[quote=Santa;446153]LOL well I'd hope those without kids don't speed outside of schools either. Just respect the fact mate that posting about committing illegal acts isn't going to be tolerated[/quote] Santa is grumpy as he's out of work til December =) So do as you're told.
Post 446174 by T5frankie on 2012-01-07 20:15:30
[quote=Santa;446153]LOL well I'd hope those without kids don't speed outside of schools either. Just respect the fact mate that posting about committing illegal acts isn't going to be tolerated[/quote] for a start i didnt say if it was on a public road or not so cheer up numpty boy
Post 446178 by Santa on 2012-01-07 20:16:50
[quote=LiamT4;446158]Can i ask how the law works regarding this issue? I means if theres no witness/video etc, then how can you be prosecuted for typing a sentence? Wheres the proof, you could be making it up.[/quote] Why force the forum admin team which tries to act in the members interests into a difficult situation where they may be forced into handing over all data they have on a member. Its hard to draw a line where it is and isnt acceptable to discuss illegal acts. Basically if you've broken the law and you haven't been convicted of it consider yourself lucky and don't post about it in public. Just to clarify, discussion of illegal activities, whether that be murder, speeding, fraud, piracy is strictly forbidden. If you want to claim you've done 150mph on a private airfield thats fine.....if you want to claim you've done 150mph thats fine......claiming you've done 150mph on the M1 isnt!
Post 446181 by Santa on 2012-01-07 20:17:39
[quote=mitchyboy01;446168]Santa is grumpy as he's out of work til December =) So do as you're told.[/quote] See, Mitchyboy gets it :-p
Post 446182 by T5frankie on 2012-01-07 20:17:45
sense of humour failure pmsl
Post 446187 by Dangerous Dave on 2012-01-07 20:19:56
[quote=LiamT4;446158]Can i ask how the law works regarding this issue? I means if theres no witness/video etc, then how can you be prosecuted for typing a sentence? Wheres the proof, you could be making it up.[/quote] The powers that be want to rape you for anything they can, so they'll find a way to do it. If its easier/cheaper for one person to trawl the web looking for muppets who post their misdoings rather than having a team of people wandering the country looking for said people then thats what they'll do.
Post 446191 by smithy on 2012-01-07 20:21:42
i did 110mph on a drag strip lol
Post 446197 by Santa on 2012-01-07 20:23:41
[quote=t5frankie;446182]sense of humour failure pmsl[/quote] Probably, its been a hard few days..........either way its given me a chance to make our stance more clearer. Anyway this threads off topic.
Post 446208 by fassi1 on 2012-01-07 20:32:31
I agree, i shouldn't have posted that top speed achievement. Getting back to my mode i probably will go for new panel filter and that will be all for now :)
Post 446213 by LiamT4 on 2012-01-07 20:35:02
The law really is an ass sometimes.
Post 446215 by Santa on 2012-01-07 20:36:03
[quote=fassi1;446208]I agree, i shouldn't have posted that top speed achievement. Getting back to my mode i probably will go for new panel filter and that will be all for now :)[/quote] No worries mate :-)
Post 446219 by t5_monkey on 2012-01-07 20:39:42
http://www.cbc.ca/news/canada/toronto/story/2010/08/10/facebook-speeding-conviction658.html "A 19-year-old man from a Toronto suburb has pleaded guilty to careless driving after boasting online that he drove 100 kilometres an hour over the speed limit on a residential street." If you say something, it could be used as evidence although if there's no supporting evidence it's unlikely to end up in a conviction. That said if you claimed you did it do you really want to have to stand up in court and say you didn't ?! I was on the STOC forum and got a strike for saying that a guy got angry with me because I accelerated faster than him from a set of traffic lights! This forum is very reasonably moderated IMHO and many car ones are much stricter. Since I only ever accelerate in a brisk and safe fashion to 70mph on Motorway slip roads I wouldn't know about this of course :)
Post 446220 by Al115 on 2012-01-07 20:40:46
TBH it's a pain for the Mods to have to look out and clean up this stuff, which is another good reason for forbidding it :)
Post 446271 by Dangerous Dave on 2012-01-07 21:04:06
Should have gone with the 'Hot Chick' thread, no one would even be thinking about posting 'I did XXXmph on a public highway'
Post 446291 by fassi1 on 2012-01-07 21:12:57
What filter should i get? JR or K&N ?
Post 446321 by t5_monkey on 2012-01-07 21:25:48
[quote=fassi1;446291]What filter should i get? JR or K&N ?[/quote] Neither... cause your car won't go any faster. If you do want to change the standard intake (which you don't need to) go for a CAIS intake rather than an open cone. It will sound wicked with a K&N though.
Post 446353 by fassi1 on 2012-01-07 21:39:10
Are u talking about this sort of kit? http://en.bsr.se/products/4900705/ I'm not expecting more power from JR or K&N panel filter, maybe better throttle response?
Post 446362 by Santa on 2012-01-07 21:42:27
Elevate AMS, thats an air filter
Post 446370 by t5_monkey on 2012-01-07 21:44:28
[quote=fassi1;446353]Are u talking about this sort of kit? http://en.bsr.se/products/4900705/ I'm not expecting more power from JR or K&N panel filter, maybe better throttle response?[/quote] Yeah that's still an open cone... this is a CAIS (cold air intake system) example that fits the S40 - basically where the air is fully taken from outside the car not inside the engine bay where heat soak can be an issue. http://www.grahamgoode.com/website/tech.php?website=9&item=60 I wouldn't worry about your intake too much at the power and tuning levels you're at right now - whack a K&N Panel filter in and forget about it. You'd be better off spending the cash on the suspension (ARB, springs, dampers) :) leave the intake till later down the track.
Post 446419 by fassi1 on 2012-01-07 22:09:51
U probably right mate. Thanks for all the advices.
