Post 446681 by dalhousie2008 on 2012-01-08 10:04:27
Hi all better do a build thread. Started with a 73k 854 t5 with good-ish history but a few body blemishes especially bumpers (old man who couldn't park)
This is my daily driver so im not going too mad
To do list:
Done:
Titans
Front pipe de-cat
Bsr cat back exhaust
Boost Gauge
MBC
19T Turbo (in process of sorting)
White injectors
850R Clutch
Strut Brace
To do:
Tidy body work.
310 or custom map
Interior t5r / 850R
Lower car (springs or kit) poly's
Brake upgrade, either porsche or xc90 brakes once how to fit them is finalised.
Not too bad as i've only had it about two weeks and it came standard and sorting the 850R at same time.
Should have a reasonably nippy daily driver.
Post 446698 by smithy on 2012-01-08 10:58:17
[quote=dalhousie2008;446681]Hi all better do a build thread. Started with a 73k 854 t5 with good-ish history but a few body blemishes especially bumpers (old man who couldn't park)
To do list:
Done:
Titans
Front pipe de-cat
Boost Gauge
MBC
White injectors
850R Clutch
Strut Brace
To do:
Tidy body work.
310 or custom map
Interior t5r / 850R
Should have a reasonably nippy daily driver.[/quote]
sounds like a nice build mate but you could do with putting it in the build section of the forum though.
Post 446704 by dalhousie2008 on 2012-01-08 11:13:15
Not really Going to town just a reliable driver I'm after. I have a really good engine sitting so may put h rods in that, plus bit short on time as rebuilding house
Post 446717 by dalhousie2008 on 2012-01-08 11:59:07
Would I need new pistons with h rods?
Post 446720 by LiamT4 on 2012-01-08 12:06:24
Depending on what boost levels your going for with the 19t, i'd go for bigger injectors than whites. Greens off the S60/V70R or the vxr injectors would be a much safer bet.
Post 446723 by dalhousie2008 on 2012-01-08 12:13:56
only gonna run a 310 map probably and set the mbc low, but i have a 16t i can use instead , im not too fussed as its only a round town car. more reliability i need than anything else
Post 446870 by Niles on 2012-01-08 19:26:48
t5r saloon still here if you want it mate. MINT condition. Rare as hens teeth.
Post 446880 by dalhousie2008 on 2012-01-08 19:33:03
Niles what are you charging to rebuild a turbo?
Post 456495 by dalhousie2008 on 2012-01-29 20:03:23
Right peeps, where have I got to
Done so far
Interior finished in black 850r seats, completely including roof lining all plastics.
Lowered Monroe shocks and springs minus 40mm
Struct brace omp
302mm disc braided lines all round plus 5.1 fluid
Titans
Splitter
Looked at bodywork t cut / mop
Boost gauge
850r clutch and rear seal
Poly bushed top mount
To do
ECU
Exhaust
Maybe turbo?
Might start 850r?
