Post 448178 by Hunter on 2012-01-11 18:49:58
I note that the C30T5 engine has 2521cc which is the same capacity as the engine in my S60R. So, the question is: can my R engine be dropped into a C30, or would I be better getting my nurse to put me back to bed?
Post 448207 by Santa on 2012-01-11 19:37:46
[quote=Hunter;448178]I note that the C30T5 engine has 2521cc which is the same capacity as the engine in my S60R. So, the question is: can my R engine be dropped into a C30, or would I be better getting my nurse to put me back to bed?[/quote]
I think the S60R engine is physically bigger. Think T5Monkey or someone else knows for sure.
Post 448335 by Wobbly Dave on 2012-01-11 22:12:44
Best route for maximum umph out of the C30 is to bolt on all the RS focus bits - larger injectors, larger FMIC & turbo changes. remapped you can get to 500NM. Then the challenge is getting it onto the floor.
Post 448337 by t5_monkey on 2012-01-11 22:16:26
I asked the Bearataur...
He says no due to the ancillaries being different.
I've got shedloads of mods on mine mate feel free to drop by and I'll show u mine!
Stock suspension setup is a bit ruff on the C30/S40/V50
Get it remapped, FMIC and sort the suspension out.
Post 448341 by Wobbly Dave on 2012-01-11 22:21:42
Bearataur is both fierce & wise.
Post 448386 by Hunter on 2012-01-12 00:07:37
OK, thanks guys. I'll stick with the S60R for the time being. It's cost me enough money, I might as well get some use out of it. Appreciate the guidance though :)
Post 448501 by Wobbly Dave on 2012-01-12 15:53:50
Don't thank us - thank the Bearataur!
Post 748876 by Carpathia on 2014-11-21 21:02:49
So bearataur.
I have a question, with many Eaton M45's floating about what's stopping any forced induction in the c30 range from dropping the turbo off and adding the supercharger?
This question applies to petrol and Diesel engines?
Post 748877 by Ettienne on 2014-11-21 21:07:15
Iirc the block is physically bigger on the s60r as well. They narrowed the c30 engine by 40mm (and focus) making them even more prone to cracked liners.
Post 748880 by stribo on 2014-11-21 21:15:00
[QUOTE=Carpathia;748876]So bearataur.
This question applies to petrol and Diesel engines?[/QUOTE]
Why lose the turbo? Just do what Colin's done to his 850, and compound charge it.
Post 748881 by Carpathia on 2014-11-21 21:17:28
Fair point,
On the Ic side, which is the best from volvo's parts bin to fit. I'm looking to keep costs relatively low (so he bolts an SC to it) and compatibility sorted
