Front fogs for the p1 V70.
Post 452208 by foammanmark on 2012-01-20 16:51:33
Just got a pair for the T5, and I presume that I can fit them without removing the bumper please? Anything I need to be careful of please whilst changing these?
Post 452219 by merc85 on 2012-01-20 17:02:27
[quote=foammanmark;452208]Just got a pair for the T5, and I presume that I can fit them without removing the bumper please? Anything I need to be careful of please whilst changing these?[/quote] The Bulbs or Light units? the Light unit itself, is attached to the Car, and Not the Bumper. Bulb fitting pritty straight forward, think you have twist/unscrew/turm the back of the light/holder. On a 850 anyway
Post 452222 by foammanmark on 2012-01-20 17:05:28
[quote=merc85;452219]The Bulbs or Light units? the Light unit itself, is attached to the Car, and Not the Bumper. Bulb fitting pritty straight forward, think you have twist/unscrew/turm the back of the light/holder. On a 850 anyway[/quote] It's the whole units that I'm fitting please, and as I've just posted on Frankie's bulb thread, the bulbs in these are H1's.
Post 452233 by merc85 on 2012-01-20 17:13:25
[quote=foammanmark;452222]It's the whole units that I'm fitting please, and as I've just posted on Frankie's bulb thread, the bulbs in these are H1's.[/quote] It is indeed a H1 LLB448, sorry for the confussion. hope this helps looks like the bracket attaches to the car. http://www.volvopartswebstore.com/showAssembly.aspx?ukey_assembly=233766&ukey_make=865&ukey_model=12011&modelYear=1998&ukey_category=7858&ukey_driveLine=457&ukey_TrimLevel=11155&ukey_modelRange=0&searchString=
Post 452235 by volvo on 2012-01-20 17:16:33
Hi Mark they are very straight forward to fit/remove mate. jack the front of the car up, have a look under each fog where they are fitted to your car and you will see the nuts/bolts etc to where the brackets are mounted. Disconnect the plug/s, remove the brackets from where they mount the car and hey presto! Cheers
Post 452238 by foammanmark on 2012-01-20 17:20:30
[quote=volvo;452235]Hi Mark they are very straight forward to fit/remove mate. jack the front of the car up, have a look under each fog where they are fitted to your car and you will see the nuts/bolts etc to where the brackets are mounted. Disconnect the plug/s, remove the brackets from where they mount the car and hey presto! Cheers[/quote] Fantastic! Bought a trolley jack this week off a work mate, so good excuse to try it. I've had a couple of scary moments with the scissor jacks recently, so that's why I bought it!
