dynamat
Post 452297 by abdul on 2012-01-20 18:51:20
Is it worth dynamat car
Post 452300 by p fandango on 2012-01-20 18:54:10
even with all the bass BT had she never rattled so didn't bother
Post 452302 by deathrider311271 on 2012-01-20 18:55:04
very good stuff but you will add a shed load of weight, on the plus side your ride will be very quiet
Post 452365 by endo-t5 on 2012-01-20 19:59:49
I've had a look into this on audio forums and some have used carpet underlay to good effect and cloud 9 is probably what I will use.
Post 452405 by abdul on 2012-01-20 20:33:47
Anybody know a installer near Manchester
Post 452446 by I want a T5 on 2012-01-20 21:27:09
In the past, I used the stuff off of Car Audio Direct.....better I think than the Dynamat and cheaper too. For my V70 T5, I shall be using it only on the front doors, both the inner and outer skin as the reat of the car seems pretty solid. Remember though, this stuff is for deadening of the panels to stop resonance, carpet underlay is good for sound insulation. Ideally, use a combination of both an insulator and a deadner.
