Post 452653 by Mongo on 2012-01-21 15:46:48
Hi all does anybody no what mk2 rs focus engine bits will fit the 2.3 t5 engine i may have access to a fully built engine.
None..... cause it's a different engine.
Gearbox will.
Gearbox?? What will i need to fit it list of everything if possible
Er... Not sure which flywheel/clutch you'd have to use, But if I was doing it I'd look at lightened single mass and uprated clutch. People say it's no better top end than the M56h. But as our cars don't like low rpm high boost, I only see that as a good thing, As the revs will be higher at each change. LSD too I believe. And I think the linkage is different too, Not sure on that one though.
